Dominator preference
#81
We did not do any steady state pulls. We will when the engines go back on. Although it seems all these pulls could have been done better and provided more detailed and accurate info, their purpose was just to see where power was going with each comb and I guess that was accomplished. The engines are going back on again and they will be swept slower and run steady state. As far as sweep rate, I was just curious as to why someone that builds all manner of boat engines would set the rate so fast. Even completely stock black motor rebuilds that come in from the marina get run before they are returned to verify they have no problems and those customers likely don't even know or care that they were run. He runs the piss out of this dyno and should know it like the back of his hand. Might just be bs but he claims about 14k pulls and he knew exactly where each combo would peak before it ran. He doesn't lack experience, that's why some of this just doesn't quite make sense.
Straight bottoms and flat decks
#82
IMHO: Set it for the 300rpm/sec rate.
Reason for acceleration rate options on a dyno is to try to match what the engine's acceleration rate is actually in the vehicle. Example: think how fast the rpms climb when you go WOT in a chosen vehicle.
A boat will accelerate less quickly thru it's rpm range then a, say 4000lb car, vs a 2800 tube frame Camaro, vs a rear engine dragster. Again, this is reason why you can choose different acceleration rates on dyno. To better match how engine will accelerate thru rpm's in real life.
I want to add in my post above, any time I see a BSFC (how much fuel is used per horsepower uncorrected) in the .300's to alomost .400, a red flag goes off in my head telling me that the corrected hp is going to be a lot higher than as measured. So, with my above post, if the fuel use is lagging behind because of the huge acceleration rate, this may make the corrected hp % (not actual corrected hp # ) look higher than it is.
Edit in: I slept on it, and saw I was headed in wrong direction. Lagging fuel flow reporting will not change corrected #'s.
Sorry, hard for me to write/type some things down. Hopefully someone will understand what I'm saying here. LOL.
#83
Here is some info that may explain some of the low BSFC's and possibly make a correction factor look higher than it is.
Since we can see uncorrected hp by looking at fuel flow + other info , what if the fuel flow is lying to us ?
Here's where I am going,
The faster the acceleration rate, the more lag there is in things like airflow and especially fuel flow. It's not just data to computer lag, but more an actual lag of fuel going into the carburetor.
More commonly, 300rpm/sec and 600rpm/sec acc rates are used. You can see fuel flow rate differences between those tests.....so I would ASSUME (never been a part of anything higher than 600rpm/sec) that the fuel rate recorded would be way behind.
Anyone on board with this ? Or.... ?
#84
I just noticed another parameter titled: Inertia- ft lbs- sec. This was in the same area where he input hi-low sweep limits etc. What would that be?
#85
Just for kicks I went to the go-fast website and plugged in some numbers for different boats and their calculators have the same mindset I do. I plugged in 1600 hp for a heavy v-bottom and then plugged in 1760. There was a 4mph difference. I said sometimes there's only 2-3mph, so I was 1 mph off on my guestimate using their calculator. Then I used a 50 hp gain (25hp each engine) and it netted only whopping 1 mph gain in a heavy v bottom. Lastly, on a fast cat with a 300 constant factor the increase of 160 hp netted 6 mph.
Site disclaimer: "There are so many factors that affect boat speed that it is hard to make accurate estimates of what the real top end will be. Mercury Marine uses the following formula to estimate potential top end, this calculator uses this formula."
To support what I originally posted. Even when using the speed calculator, there's no magic formula to say that X power increase results in X mph increase. case closed. :-)
#86
#87
#89
I plugged in 840hp (stock 420s)total in a heavy vee weighing 8500lbs like donzi matts boat. Said 71mph. I plugged in 80hp per side more for 1000hp total, said 77mph. I then plugged in 25hp per side more, 50hp total , and got 73mph. Seems like his assumption of a 2mph gain equating to around 20-25hp per side, is a heck of alot closer than 80hp per side than his engine designer claimed. At least in that application.
#90
One last example, that is exactly why I asked him what kind of boat it was. But it wasn't made clear to me. You seem to know, but I don't.
