Dominator preference >
Old 03-09-2016 | 06:56 PM
bck's Avatar
bck
Charter Member#568
Not ambitious enough to scan all the graphs now and should really start another thread but because 4150s were mentioned here's some info we found fwiw.
The 4150 on a Vic Jr
674hp @ 5600 with an average 514.
645lb @ 5300 with an average 610.
The 4500 on a Vic Jr
686hp @ 5800 with an average 529
659lb @ 5300 with an average 620
Straight bottoms and flat decks
bck is offline
Old 03-09-2016 | 07:08 PM
Originally Posted by bck
Not ambitious enough to scan all the graphs now but fwiw.
674hp @ 5600 with an average of 514.
645lbs @ 5300 with an average of 610.
686hp @ 5800 with an average of 529
659lbs @ 5300 with an average of 620
Nice. More average torque with the dominator as well.
MILD THUNDER is offline
Old 03-09-2016 | 07:10 PM
bck's Avatar
bck
Charter Member#568
Yes outperformed it across the board and this particular 4500 was the first generation when they called them NASCAR carbs. I imagine a modern one would have done better. All the later 4500 testing was done with a modern QF
bck is offline
Old 03-09-2016 | 07:11 PM
SB
What about the intake swaps as you mentioned before ?
And 500rpm spread from pk tq to peak hp ? Or did you cut the pulls short of higher rpm ?
SB is offline
Old 03-09-2016 | 07:19 PM
bck's Avatar
bck
Charter Member#568
SB- We also tested a 454 R / 4500 with no spacer, 1in spacer and 2in spacer. We hit the hp peaks with all the combos, didn't cut any short. I'll start another thread when I can with all the info. Still not done yet. The 4150 in the above test climbed so well to 5600(the limit of that pull) that everyone thought it would keep going, but when we did another pull to a higher rpm it was all done at that original 5600 peak. I don't know what to tell you about the peak to peak spread.
bck is offline
Old 03-09-2016 | 07:29 PM
SB
Sorry for jumping the gun, Doh !
Did the 4150 go 'fat' by any chance at/after 5600 and fine before it ?
SB is offline
Old 03-09-2016 | 07:34 PM
bck's Avatar
bck
Charter Member#568
Go fat meaning? I have the sheets in front of me now, what specifically would you like to know?
bck is offline
Old 03-09-2016 | 07:38 PM
Go rich fuel wise in the upper rpm is what he's asking
bck's Avatar
bck
Charter Member#568
Last edited by bck; 03-09-2016 at 08:15 PM. Reason: Answered more completely by picture
bck is offline
Old 03-09-2016 | 07:39 PM
SB
LOL.
Does this fuel curve make my carb look fat. Heh, heh.
SB is offline
