installing prop on #6 drive >
Old 03-13-2016 | 06:44 PM
Default installing prop on #6 drive
I had a prop nut come loose on me. I re-torqued it however the prop 'wobbles' a little on the shaft. I switched props and the new set are tight on the shaft. I am guessing that I screwed up the old prop? So what did I do wrong besides let the old one get loose? I always put a small amount of grease on the splines, should I be putting them on dry or with a special grease?
any input would be great
scarab39 is offline
Old 03-13-2016 | 07:13 PM
There should be the proper plastic spacer in the prop. The 3A, #5 props, take a different bushing than a #6 prop. my guess, is you simply don't have the bushing at all. Its held in by a plastic snap ring from the front side (bow side) of the prop.
MILD THUNDER is offline
Old 03-14-2016 | 04:28 PM
Yep, the plastic was gone. Thank you
scarab39 is offline
Old 03-14-2016 | 04:30 PM
No problem.
Bblades has those plastic bushings in stock I believe.
Old 03-14-2016 | 05:08 PM
my #6 drysump drives use a ss washer and then the big nut.i have herring props with no plastic bushings and my props don,t wiggle,i torque the nut to 100 ft lbs.
mike tkach is offline
Old 03-14-2016 | 05:15 PM
I dont know about the herrings, but the 26 spline merc props are made to fit both 3A, V, big shaft IV, as well as the slightler larger diameter #6 shaft. The shafts on the 6 drive are slightly larger, so the bushing is made to be removed and replaced per the application. Ive changed them out before, they are there. Alot of guys dont know, and run around without the proper bushing, and the prop actually only stays square on the shaft due to the nuts torque holding it
Old 03-14-2016 | 06:19 PM
14 apache's Avatar
Some mercury props for #6s don't have bushings they where early.
14 apache is offline
Old 03-14-2016 | 11:40 PM
SFOcean's Avatar
Charter Member #394
Yeah, I have some props I use on my #6 that take a bushing and others that do not.
SFOcean is offline
