Map sensor 502 Mag MPI
Anybody ever replace one with an automotive one ? Merc wants $ 165.00 where as one from Napa is like $ 45.00 I think it is a 1 bar ??? Just guessing.
Thx
Thx
Perfect. Thank you !!
It is wise to check with a scan tool your MAP readings after changing from one to another brand maker. MAP sensors all are not created equal and the same goes for IAC's - when buying from different manus but still is the same part. I have tested this with the scan tool as well and the readings can be different. Sensors come into play alot when it comes to air & fuel delivery, throttle response and idle quality .
MAP sensors 2 bar for SC engines for low to mild boost
1 bar for NA engines
It is wise to check with a scan tool your MAP readings after changing from one to another brand maker. MAP sensors all are not created equal and the same goes for IAC's - when buying from different manus but still is the same part. I have tested this the scan tool as well and the reading can be different. Sensors come into play alot when it comes to air & fuel delivery, throttle response and idle quality .
