Stud Girdle
Old 02-15-2017 | 04:59 PM
  #51
Originally Posted by MILD THUNDER
Im running the comp cams/rhs girdles on my Engine Quest heads.
Those fit like a glove on the EQ's
https://m.youtube.com/watch?v=SzD_LZ3fM-s
Did a quick search on valvetrain videos while engine running and not much came up. I'd love to see a video.
getrdunn is offline
Old 02-15-2017 | 06:46 PM
  #52
Full Force's Avatar
454AFRV2 is the part number for 2 gen AFR heads, just ordered 2...
Full Force is offline
Old 02-15-2017 | 07:54 PM
  #53
https://youtu.be/_REQ1PUM0rY here is an old video, gives an idea
I'CE is offline
Old 02-15-2017 | 08:47 PM
  #54
Funny I just posted this same one in a thread and now see you beat me to it. Oh well. The more it gets seen the better.
getrdunn is offline
Old 02-18-2017 | 11:19 AM
  #55
Originally Posted by Bawana
Looking to add stud girdles when I install my spring oilers, Wondering what you guys have used, that fit good with no binding. I talked to Brodix and they say the only ones to use are the two piece ones they and Bo Laws make. I really don't like the way those tighten to the polylocks, and I would think having a single plate would be better. They insist that the one piece girdles will not fit correct and pull or push on the studs and put undo stress on them.
The old Mec 1000SC had one piece girdles on them, and if memory serves me right, I think they used Crane?? I have never had a stud break since changing to the best ARP studs, but since I am going to add the oilers, I figured I would add girdles too. I know shaft rocker setups are better, but I am not wanting to pull all the motors to do that and the cost of the good ones times three does not appeal to me.
I have Jomar girdles for that application...[ATTACH=CONFIG]564874[/ATTACH][ATTACH=CONFIG]564875[/ATTACH] they sell for 329.00 per set and come complete with polylocks as seen
adk61 is offline
Old 02-18-2017 | 11:33 AM
  #56
Originally Posted by mike tkach
the reason for useing a stud girdle is to support the studs in an attempt to stabilize the valve train.if you install a girdle that is designed for a different valve angle it will try to bend the rocker stud.we all know what happens when you attempt to bend a hardened stud,it is just a matter of time before it fails.
that would be secondary in my concern.. what actually happens is that the girdle pulls the stud just far enough out of true alignment with the valve and you end up wiping out a set of guides in no time or worse if you don't catch it in time... proper valvetrain geometry is KEY to maintaining life and performance JMHO
adk61 is offline
Old 02-18-2017 | 12:18 PM
  #57
this is one I have used twice, and as far as when needed, after talking to Bob M. at length I thinking starting at a 500hp would not be a bad idea..
http://www.ebay.com/itm/PROFORM-Big-...FXroAR&vxp=mtr
ezstriper is offline
Old 02-19-2017 | 03:57 PM
  #58
You know by chance if they are same stud angle as the jomars. About half the price and look near identacle but just don't wanna have any alignment problems. Going on promaxx
getrdunn is offline
Old 02-20-2017 | 06:27 AM
  #59
I do not, but the fit perfect on std GM iron heads(running now) and used a set on std Darts a while back, both worked fine, now the adjuster nuts wont work on crane gold rockers without grinding, or getting thinner wall ones.
Old 02-20-2017 | 09:26 AM
  #60
I DO NOT recommend grinding the nuts... it weakens their binding efficiency
adk61 is offline
