Engine surges when warm
A lot of time surging can be fuel related. With that said it has to be a process of limitation. And of course timing / or ign related related to. Ign related is more of a miss and can get worse.
I would put a fuel pressure gauge on this first and make sure that is not a problem. (fuel delivery problem) Next I would run a true intake vacuum source test with a Vacuum gauge. Vac testing can tell you alot.
I would also run the engine on a new portable fuel supply with fresh gas and new fuel line with a primer bulb inline. Squeeze the bulb if the surging is still taking place . Anything change
A layman's simple test also is while surging spray some carb cleaner down the carb did the rpms pick up or did the engine want to stall or did your surging go away ? very basic test but can pin point a fuel problem or a very lean condition.
If he has the OEM service manual or google it they Merc have a testing procedure for knock sensor and knock module right after for the T bolt V ignition testing flow chart.
Knock sensor install is 12 to 16 ft lbs no more and nor less installed per Merc specs. I just did one on a 350 HO mag.
