AFR Gauge question >
AFR Gauge question
AFR Gauge question
Old 04-23-2016 | 08:09 PM
I rebuilt some carbs for a buddy last year. Needle and seat was 90% clogged by a piece of rubber that came from somewhere in his fuel system. I would imagine, that he would not have seen a loss in fuel psi, but certainly a lean afr reading.
MILD THUNDER is offline
Old 04-23-2016 | 08:40 PM
This gauge looks like a must for any piece of mind on a custom build. Not knocking fuel pressure gauge, I have one of those also.
Anybody added data logging to monitor with vac/tps/rpm/afr? Looks easy to add tps to carb.
GLENAMY 242SS is offline
Old 04-23-2016 | 09:11 PM
I have not used the data logging yet, most likely won't for my set up. but maybe in the future if I decide to make more power.
Keep us posted if you end up using it
abones is offline
Old 04-24-2016 | 07:50 PM
If it's that clogged and he didn't feel it laying over he needs to pay better attention to how it's running.
Unlimited jd is offline
Old 04-24-2016 | 08:34 PM
Like a huge loss in rpm.
Some like EGT's however AFR's is a much easier I think and ultimately the best way to maximize HP while egt is extremely important as well however applications can very much more with a broader band of temps making most HP. I'd like to have both to be honest however going AFR.
getrdunn is offline
Old 04-24-2016 | 08:47 PM
I'm running the AEM "failsafe" gauge..
Logs RPM MAP and AFR.
It can be set up to activate a warning if your A/F falls out of the range you specify..
http://www.aemelectronics.com/?q=pro...failsafe-gauge
Boatally Insane is offline
Old 04-24-2016 | 08:48 PM
I've welded into Gil's with blown engines but prefer not to do it on cmi's
getrdunn is offline
Old 04-24-2016 | 08:49 PM
Nice
getrdunn is offline
Old 04-24-2016 | 09:43 PM
I've welded bungs in my gils and the afr gauge will be here this week.
Mr Maine is offline
Old 04-24-2016 | 10:03 PM
Full time, AFR, EGT, intake temp and now knock sensors.. I like to know what going on.
ICDEDPPL is offline
