Engine oil dipstick options >
Old 04-26-2016 | 08:33 PM
Yes, plastic liner with Stainless over braid and a properly supported tube ID compression joint akin to an AN fitting. No leaking and properly contained polymeric tube.
My boat doesn't have a plastic pick up tube but if it did, I'd probably be fine with it since that application does not involve typical oil temps which are the challenging aspect for thermoplastics.
To each his own but the 50 bucks it cost me to have a dipstick I know reads correctly and doesn't leak was well worth it.
GoodTrade 2750 is offline
Old 04-26-2016 | 09:27 PM
I like the long dipstick my 97 454 dually has. It has the yellow pull ring, with the o ring on it. Maybe i just need to get some proper ID nylon tubing, cut to length, and use those GM dipsticks .
MILD THUNDER is offline
Old 04-26-2016 | 10:14 PM
I just did that with a buddy, except we used 1/4 inch copper tubing flared to the 90 degree fitting on the aluminum pan. The dipstick is from a 98 Chevy pick up with the yellow pull ring. Old dipstick was way too short, we matched up the full marks, works perfect.
Mr Maine is offline
Old 04-26-2016 | 10:33 PM
We just make our own. I buy a stick from GM for a van. I buy bulk -6 SS tubing and bend them myself with a tubing bender. I use a black anodized nut and ferrule and flare the end of the SS tubing. Our pans have a 1/4" NPT female bung. I put a 1/4" x #6 fitting in the pan. The tubing attaches to that fitting where I flared it. We then fill the pan with the correct amount of oil, cut off the excess stick, and remark it. Works great. I can post some pics if you would like.
Eddie
Young Performance is offline
Old 04-26-2016 | 11:42 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Eddie
Please do Eddie . Thanks
the deep is offline
Old 04-27-2016 | 05:33 AM
Eddie
Now that's the way to go!
Not surprised considering the source....
Old 04-27-2016 | 10:20 AM
cool
hotrodford is offline
Old 04-27-2016 | 10:55 AM
Eddie
Thanks eddie ! Pics would be nice, but i understand what youre saying . Sounds like a good way to go
