Holley EFI in a boat - Doesn't Repeat >
Old 05-19-2016 | 03:07 PM
  #31
Originally Posted by SDFever
Also, there are other bugs in it as well. .. Like regardless of how many times and when you cycle ignition it has saving issues as well.
I'll tell you what, I'll take that fuggin POS junk Holley off your hands. I ain't gonna pay much for it though, since it's a giant turd.
Haha
Wasted Income is offline
Old 05-19-2016 | 04:14 PM
  #32
I do run fast, but haxby can remote tune those as well. I called and left a message, but no return.
I understand, he is busy.
Larry
ldillow is offline
Old 05-19-2016 | 06:31 PM
  #33
mcollinstn's Avatar
Running great in closed loop and "all over the place" in open loop GENERALLY means the basemap isn't optimized for your in-boat setup.
Vacuum leaks, sensor connections, fuel pressure stability - those also can trigger frustrating problems.
M
mcollinstn is offline
Old 05-19-2016 | 06:41 PM
  #34
I've been running ms3pro's for a couple years now, they worked great at first but moisture killed them. I don't know if Holleys are as sensitive but it might be worth considering
https://drive.google.com/file/d/0Bxo...ew?usp=sharing
scarab39 is offline
Old 05-19-2016 | 07:18 PM
  #35
The Holley is fully potted.
indysupra is offline
Old 05-20-2016 | 06:26 AM
  #36
heres a couple of things, find someone who has made this stuff work..alex haxby, make sure your 02 is not getting ANY water back to it, I have been down both the roads and will drive you nuts
ezstriper is offline
Old 05-20-2016 | 09:32 AM
  #37
that's another issue is the o2 sensors, the clock is running on them. I've had them last a month, and a week. They hate salt water even worse. Get your tune locked down, then get into open loop.
launchpad475 is offline
Old 05-21-2016 | 10:14 PM
  #38
I'm switching to Holley. is anyone here ( Haxby? ) a reseller for Holley? I need two dominators
scarab39 is offline
Old 05-22-2016 | 10:13 AM
  #39
offthefront's Avatar
I've been running the Holley system for over 4 years with no issues ....closed loop the entire time ... I do not "learn" below 1200 rpm ....we did kill a cpl of O2's at idle at first and then it would dump a bunch of fuel ...the fix for that day would be to go back to base tune in open loop ... I carry a spare O2 sensor but since the change at idle no issues for quite a while ....always carry my tablet with me just in case ... 540 M3's 850hp ....
Just a note we did have some issues on the Dyno .... I believe the dyno had some RF issues and since in the boat they are nonexistent ...........m
offthefront is offline
Old 05-22-2016 | 11:55 AM
  #40
Same for me - 4 seasons now with Holley HP on stack injection unit. I only activate closed loop & learn above 1500rpm. Also carry a spare o2, but haven't had to change one since I ran across and started using this item (just a little more protection from water with no noticeable difference in AFR reading).
http://www.innovatemotorsports.com/x...cat=250&page=2
rvander68 is offline
