575sci refresh >
575sci refresh
575sci refresh
Old 05-16-2016 | 06:14 PM
Default 575sci refresh
What parts are normal "rebuild" parts in a 320 hour 575sci. 2003 model year engines. Still have the flat tappet cam. Have ran a lot of those 320 hours with them turned up. I have a friend getting some quotes and I'm surprised at how little is on the parts list by the shop he is wanting to do the work.
indysupra is offline
Old 05-17-2016 | 10:40 AM
Rebuild heads. I also did roller cam while engines were out. Then in water ECU tuning. Call Eddie Young.
ALL_IN! is offline
Old 05-17-2016 | 01:16 PM
Thanks for the response. He was planning on cams but I was more curious about Pistons, rings etc. I don't see how a performance marine engine with 320 hours does not need more than a hone job. This one shop is proposing an In house hone job(ball hone or stone hone) rings and rebuilt heads. Seems like that is optimistic.
Old 05-17-2016 | 02:31 PM
Leak down should have determined if bottoms ends need freshening. Mine have 306 hours now - and run strong.
ALL_IN! is offline
Old 05-17-2016 | 11:32 PM
the cylinder bores will need to be checked for size,taper and out of round,imo the shop that just wants to do a hone job without checking the bores should not be used[nothing personal as i have no idea what shop said this].320 hrs is not a lot and maybe a hone job will do it but without checking it,s not posable to know for sure.
mike tkach is offline
