anyone ever have a sound like this  ? >
Old 06-27-2016 | 10:18 PM
Sounds like a cracker fly wheel to me.
offshoreneil is offline
Old 06-27-2016 | 11:00 PM
Is that different from negro flywheel?
Mseuro is offline
Sorry couldn't resist
Mseuro is offline
Old 06-27-2016 | 11:53 PM
Sounds like internal exhaust tip flapper to me. Put your hand on the tailpipe hose near the transom.
Does it go away with some rpm?? Flapper noise will go away with with a few hundred more rpms.
Griff is online now
Old 06-28-2016 | 07:37 AM
Yes. Way different. Lol!
Donziben is offline
Old 06-28-2016 | 10:03 AM
Negro flywheel would be a lot larger, right?
My boat has developed what I would describe as a "chirp" coming from the exhaust, but it is a steady sound that seems to be in time with the firing order. Ran a compression test the other night and all were at around 180 - 185 psi. Some OSO'ers have said that it might be a loose baffle in the exhaust muffler. Planning to try some different muffled tips to see if it changes any. Good luck with yours.
Budman II is offline
Old 06-28-2016 | 10:16 AM
BUP
stick broom handles up the transom exhaust to keep the internal flappers open while running the engine - this will rule in or out if thats your noise. Process of elimination the start of it
pull tips / mufflers shake the hell out of them by hand --- Noise ??? run engine however without the tips / mufflers installed ---- Noise ???
A real doctor stethoscope will find this noise in about 15 seconds. Use one all the time best tool to have for marine noises hands down.
BUP is offline
Old 06-28-2016 | 10:54 AM
Were you at Cumberland Thunder Run???
There was a boat in my fleet that had a chirp noise from exhaust. ...and somehow I got behind him at each stop. That chirping noise was driving me crazy!! LOL
ALL_IN! is offline
Old 06-28-2016 | 10:59 AM
Bill 3's Avatar
My vote is an exhaust flapper. Does the noise change or go away with a little rpm?
Bill 3 is offline
Old 06-28-2016 | 11:12 AM
No not really , I took the recirculating pump / alternator belt off and it seemed to go away but the engine got louder (threw me off a bit) but I think the RPM's just went up because of the belt being off . So I think it's the alternator or the recirc pump and I will try eliminating the flappers as a possibility as well
professor is offline
