Does when in forward but not reverse
In order:
Base idle timing spec is 8* .
Most module's is typically the 24* unit, so this would give you 32* total, Double check of course.
One at a time, slowly turn idle mixture screws and see if each will make the carb stall. If not, they have some cleaning to do.
Once that is settled, move each idle mixture screw for most intake vacuum.
Set idle speed (neutral) for 700rpm when hot.
