Cutting Bravo Lower (it's done!!!) >
Old 10-11-2002 | 03:04 PM
  #51
454hoho
Default form/31
I dont have a fax number to sent this to. 6pages. asfor new or old bravo not sure havent reread the article but was written around 2000 and pics show low water pickups
Old 10-11-2002 | 03:15 PM
  #52
454hoho
Default nose cones
Audacity had posted info awhile back about nose cone dont work. the guy races in f2 class and has a lot of knowledge. Some people say they work some say they dont work. My cones are bullet/pointed and welded on, but I think if i had a choice i would go with blade type(less effected by trimming drive in/out)
Old 10-20-2002 | 09:09 AM
  #53
mxz800's Avatar
so how did the testing go? did i miss the results??
mxz800 is offline
Old 10-20-2002 | 09:23 AM
  #54
Maxx's Avatar
I'm still waiting to hear from Tommy V. I do plan to change a couple of things, though. Namely the cavitation plate; I think it would be better to remove it for prop clearance reasons. To strengthen the weld margin, I plan to lay in a peice of 5052 aluminum flat bar over the margin and weld it in place. Like I said before, my biggest concern is durability.
Maxx is offline
Old 10-21-2002 | 12:31 PM
  #55
tommy v
Default HI EVERYBODY
HOPEFULLY WILL BE ABLE TO TEST THIS WEEK BEEN RAINING HERE EVERY TIME WENT TO PULL BOAT HOPEFULLY TEST THIS WEEK THANKS
Old 10-22-2002 | 07:41 PM
  #56
Another reason for a loss when going from Alpha to Bravo is the mass of the Bravos larger shafts and gears and so on, takes more HP to turn them............Doug
pullmytrigger is offline
puder
6
02-23-2011 07:05 AM
Maxx
44
02-16-2007 06:17 PM
CONDOR24
1
03-18-2003 05:41 PM
Maxx
17
10-01-2002 09:14 PM
Maxx
3
08-19-2002 12:27 AM
