How fast can I go >
How fast can I go
How fast can I go
Old 09-14-2016 | 02:20 PM
I'm not sure... I know it's a hi-five. I top out at 45 at about 46 47 rpm
goodboy is offline
Old 09-14-2016 | 02:26 PM
Originally Posted by DBleil89
Also idk how light that boat is, but I had a maxum that went over 60. It didn't chine walk bad and handled it pretty well. The only problem I found is when going that fast and hit much of a wave it would get air under the nose and start picking it up. It would lift enough you had to back off the throttle slowly or it would flip. 20 foot open bow boats are usually pretty light so just be careful to get to know it when it's done.
The more I read and look at other boats I think I should be able to get to 60 without much problem. I've operated a couple of boats that were over powered an 60 plus... Never had a problem with wanting to blow over but chine walk was an issue.
Putting the parts list together for my motor... Looking at proly 350+ hp.
Should get me to almost 60 I think... Adding 150hp should be a big Improvement lol.
goodboy is offline
Old 09-14-2016 | 02:30 PM
SB
Yup, if a 350 hp 5.7L won't get that to 60,it's a pig. LOL.
SB is offline
Old 09-14-2016 | 02:39 PM
My thoughts exactly... And I'm building a 383 with the added torque... 350/360hp should get me to 55 and maybe 60. I'm not really interested in the top speed... But really looking forward to cruising at 40 without the motor working that hard
goodboy is offline
Old 09-14-2016 | 04:56 PM
A High 5 prop probably isn't the best prop for that, especially for top speed. Look for a Mirage Plus style prop to at least try with your new setup. Regarding how it will handle at top speed depends on the hull, conditions, prop, driver, and tabs.
Mr Maine is offline
Old 09-21-2016 | 07:01 PM
That boat will do 60 all day with a 383 unless you totally wimp out on the engine build stuff. My 4000 lb 23 degree load does just about 60 with a fairly well designed 383.
NHGuy is offline
Old 09-22-2016 | 01:08 AM
From the pic, that drive/ X dim is in the basement. That will make it quick to plane, but slower at WOT.
Griff is offline
Old 09-22-2016 | 07:48 AM
speed cost $$$$ how fast do you want to go...not a performance boat, so ?
ezstriper is offline
Old 09-22-2016 | 08:42 AM
Most 21 foot scarabs ran 60 with 260 horse and a 1.5-1 drive.
Your boat has a pad bottom like the scarab so 55-60 with a mild 383 should be cake unless the bottom has a big hook in it.
tommymonza is offline
Old 09-22-2016 | 08:47 AM
Sydwayz's Avatar
Forum Regulator
What is the biggest power package that they installed OEM on this hull?
You cannot just throw more HP at any hull, and expect it to improve speed and act/handle accordingly, linearly.
Sometimes you reach the limit of a hull's capability, and when you do; it let's you know in a hurry, and usually it's not pretty.
Sydwayz is offline
