Driving thru chine walk >
Old 09-15-2016 | 02:06 PM
  #41
I don't know if it was already mentioned but check your toe in or out on the drives while it on the trailer.
kvogt is offline
Old 09-15-2016 | 02:42 PM
  #42
Good point for everyone to check every now and then. Wonder if props are spinning in or out?
getrdunn is offline
Old 09-15-2016 | 08:09 PM
  #43
Toe-in is neutral and the modified Mirage props are spinning out.
zz28zz is offline
Old 09-15-2016 | 08:49 PM
  #44
Nose cones? Not that I don't think that would do anything about chine but could change a lot in driving characteristics
KRAUSMOTORSPORTS is offline
Old 09-16-2016 | 01:06 AM
  #45
No nose cones. Still running the original drives from 1990.
zz28zz is offline
Old 09-16-2016 | 06:05 AM
  #46
Originally Posted by mcprodesign
A twin engine fountain should not chine walk . Check trim indicaters to make sure the trim is right at wot possition. If it porposes use trim tabs to kill it . You may gave to trim pretty high to get it to stop moving around . Sometimes fuel slosh causes problems . Check drive alignment too. Mine does not like the dtives trimmed down
I'm guessing you have never been in a twin BB 29 then
ezstriper is offline
Old 09-16-2016 | 05:39 PM
  #47
Naw just a 27 that chine walked a bit and my 38 that only chine walks when somethings wrong . I'm only trying to give all i know . Did all the 29's chine walk ?
mcprodesign is offline
Old 09-16-2016 | 05:56 PM
  #48
I really think the question that should be asked is what can be done to eliminate chine walk, not drive thru it,
Sure, your always going to get an occasional wobble, but if a boat or a series of chine walks most of the time, there is a hydrodynamic instability.
If your truck got severe speed wobbles at 60 mph all the time, would your answer be to let your family pucker while you death grip the wheel and try and drive thru it or would it be at the shop to figure out whats wrong?
phragle is offline
Old 09-16-2016 | 09:47 PM
  #49
I thought most fountains spun the props in?
MINK is offline
Old 09-16-2016 | 10:08 PM
  #50
Tinkerer's Avatar
One thing about proper set up is NO ill handling. My daytona would porpoise at mid range speeds. It no longer does at ANY speed.
Tinkerer is offline
