Cam and valvetrain longevity....??? low duration high lift... >
Old 10-07-2016 | 09:50 AM
  #1351
Originally Posted by JRider
I am not so sure about that small of runner head on a 540+CI marine engine. My 548s have Dart 360s speced by Teague and made great numbers. Bob recommended AFR 305s for my 502ci 575sci, I thought that was small as well, or was it just what he had on the shelf? As far as my cams they are Crane Hydraulic Roller 254/262 680/680. 982 and 984 a side at 8psi
Just to be clear Bob M recommended the 305s not Bob Teague.
JRider is offline
Old 10-07-2016 | 09:51 AM
  #1352
Nice to see someone finally put some cam in an engine. These. 240* 540s are a dime a dozen .
That is a big port, prob wouldnt go that route for an NA 540 marine build, the 320 darts would prob work better. But with that roots up top, low end shouldn't be an issue. Im sure yours made plenty of torque.
MILD THUNDER is offline
Old 10-07-2016 | 09:54 AM
  #1353
Yeah, missed the part about NA
JRider is offline
Old 10-07-2016 | 11:14 AM
  #1354
Full Force's Avatar
A buddy talked to kip today at cam motion said they have not had issues with harness, he wants cams to check, I plan to have frock style check them local also and compare results, I have 4 guys that wanna check them, so hard to have many involved... He did also say he's not a fan of small duration high lift but had to give Bob what he asks a for, also said I am a solid 10 degrees duration away form good power... I will be calling him myself personally later and let you guys know how my convo goes.
Full Force is offline
Old 10-07-2016 | 02:44 PM
  #1355
I see that MK was spec'ing high lift short duration for pretty much everything. So what is the theororetical value of such relative short duration? I'm flipping through a comp cams catalog and all of their cams for marine use ~.550 lift but about +20* on the duration. These seem flat and wide compared to the MK cams.
Baja Rooster is offline
Old 10-07-2016 | 03:08 PM
  #1356
Full Force's Avatar
Looking at my Dyno sheets the power spikes and falls super fast... Horrible for marine use...
Old 10-07-2016 | 04:05 PM
  #1357
It seems like that tight of a duration would give you a peaky spread of more power. Which makes sense as folks were having to prop down to let the engines get to that power, and then it would fly. Please correct me if that's wrong.
Old 10-07-2016 | 04:19 PM
  #1358
bck's Avatar
bck
Charter Member#568
I know Tim's cams had more lift than mine but mine still are outside of the norm I guess. I don't know that my power curve was particularly peaky. Perhaps I'm mistaken though not being exposed to as many combinations as some here
Straight bottoms and flat decks
bck is offline
Old 10-07-2016 | 04:26 PM
  #1359
bck's Avatar
bck
Charter Member#568
This was the peakiest pull with the 2 in spacer. I went with the 1 inch spacer because it was broader than this one and higher in torque. I don't have that graph in the phone to upload here
Attached Thumbnails Cam and valvetrain longevity....??? low duration high lift...-imag2276.jpg
bck is offline
Old 10-07-2016 | 04:45 PM
  #1360
Originally Posted by Full Force
Most look ok, there's a couple that might look like they bounced around a little,
Just curious.. What pushrods are you running ?
Boatally Insane is offline
