best hole shot Trim tab position >
Old 09-23-2016, 10:12 PM
I think I like those....where can I get them?
Originally Posted by SB
These let you bump them with side, top, bottom of finger , hand, etc,etc Much easier to do by feel when schit hits the fan vs regular rockers.
Regular rocker switches force you to push and hold.
I use these for tabs. Drive trim is on throttle as are most.
turbo rr is offline
Old 09-23-2016, 10:25 PM
SB
Received 3,134 Likes on 1,411 Posts
He's an OSO sponser.....a very good one
http://www.diamondperformanceparts.c...cat=314&page=2
SB is offline
Old 09-24-2016, 06:59 AM
VoodooRob's Avatar
Why not add a trim tab switch to your throttle? So you would have 2 switches on your throttle stick (drive and tabs). Easy to operate with your thumb.
VoodooRob is offline
Old 09-24-2016, 08:47 AM
Received 4,407 Likes on 1,263 Posts
One of the better mods , everything at your fingertips. ^^^^^
ICDEDPPL is offline
Old 09-24-2016, 08:59 AM
Originally Posted by Padraig
Hard/fast hole shots shorten your drive life. Don't do them.
Padraig
Some of us have tides and shallow creeks to deal with and need to hole shot...
Black Baja is offline
Old 09-24-2016, 11:50 AM
You do what you need to do to keep you and your boat safe. Still, the OP needs to know he may be shortening his drive life.
Padraig
Padraig is offline
Old 09-24-2016, 12:26 PM
drag boats have shafts, not outdrives. also, all the force accelerating the boat is on the propshaft, straight to the trans and to the motor mounts mounted to the stringers near the center mass. not trying to tear the transom off the boat...
dereknkathy is offline
Old 09-25-2016, 12:20 AM
Nice! Thank you.
turbo rr is offline
Old 09-25-2016, 05:10 AM
Forum Regulator
Sydwayz's Avatar
Received 1,219 Likes on 527 Posts
These boats are not designed for hole shots. Go buy a jet boat or a jet ski for that. Your outdrive (especially gear floor) and drivetrain will thank you.
Trim tabs 2/3s of the way down helps planing. Then pull them up once on plane.
Sydwayz is offline
