Help picking out a cam... >
Old 10-09-2016, 10:13 AM
As you know, we have the same combo to the carb aside from cams. Mine has a Isky cam with 525 EFI specs. Based on how the boat runs, I'd say it's in the 530HP range.
TxHawk is offline
Originally Posted by sutphen 30
I'm just thinking of his poor drive.700+hp is not gonna be kind.
Absolutely NO fat kids on the tubes...With 700 hp and supercharger torque you will pop that drive faster than a drunk homecoming queen's cherry.
phragle is offline
Old 10-09-2016, 10:54 AM
Originally Posted by Black Baja
You shouldn't have any issues with idle quality and the current cam you have. The 525 efi cam would work really well with that setup and it responds very well to boost. 236/244 @.050 114 lsa. I have one coming out of a motor in the next week. Johnson lifters as well. Cam does have a flat nose for mark iv block...
It's a Gen6 block. Would it still work?
Originally Posted by MILD THUNDER
Very true. Maybe he could stay NA, and just run a low pitch prop for those wakeboarding and tubing days. Then when not playing mastercrafter, he could bolt the big prop back on.
The charger has been sitting on it unused all season for the sake of the stock drive, and that's also why I want the option to not run it. I do plan on upgrading the drive to at least a 1x and keeping it easy on the sticks.
Baja Rooster is offline
Old 10-09-2016, 11:02 AM
yes
sutphen 30 is offline
Old 10-09-2016, 11:12 AM
Keep me posted.
Originally Posted by ezstriper
can't help much on cam, but I ran a HP500 with a procharger for years, several carbs and EFI, last setup had to go down to a 750 from a 850 to keep from leaning out at WOT, thanks god for widebands. the air was being blown thru so quickly that would not pull fuel, the 750 worked perfectly
What sort of EFI did you run and what happened with it? I plan on going in that direction.
Old 10-09-2016, 12:52 PM
articfriends's Avatar
Originally Posted by MILD THUNDER;44898hy42
I like the 525 EFI cam or similar
I towed wake boarders and kids on tubes behind my 1000 hp procharged efi 272 all the time, if i was going to have a full tank of gas and 7 people in boat AND tow i would throw a 28 pitch on, i also had 24"long trim tabs but had no problem popping up on plane and staying planed out at 20 something mph around 2800 rpms with a cam that was 245/255 then a cam that was 252/259. It was a 540 but still wasnt difficult whatsoever, fwiw, smitty
Since you tow tubers and wake boarders, I'd look into selling the centrifugal, and picking up a 250 blower. Couple that to those oval ports , should make more than enough low end, and good top end as well. Throttle actuation and response down low with a roots is very good.
Above, somehow i typed answer out in the quote and dont feel like retyping it lol
articfriends is offline
Old 10-09-2016, 01:09 PM
picts
Attached Thumbnails Help picking out a cam...-22533_1240747336658_6210345_n.jpg   Help picking out a cam...-25343_1258016368373_2969609_n.jpg
Old 10-10-2016, 01:40 AM
Double skis??? I didn't even know that those still existed!!!
It looks like the 525 EFI cam is the hot ticket here. Thanks for the input!
I'm actually thinking of chucking the super charger idea altogether. It's an open bow and once your above 50mph chit goes flying everywhere, the women start screaming, and I either run out of lake or the open waters are too rough to open her up. I just think it's the wrong boat to do it with considering the drive upgrades involved etc. I can get 63 out of her now, and a new cam plus some other tweaks oughta get me in the upper 60s which I think is the limit for this boat without reinventing it.
Old 10-10-2016, 11:43 AM
And greetings from the SF Bay during the fleetweek airshow.
Blue Angels
Old 10-10-2016, 07:03 PM
Received 1,493 Likes on 807 Posts
And to think we get a rush. Well we do but... Nice pics.
getrdunn is offline
