-   -   Oil bypass question (https://www.offshoreonly.com/forums/general-q/341861-oil-bypass-question.html)
cabin fever 10-10-2016 10:50 AM
Oil bypass question
Picked my motor up from the builder saturday. Sounds amazing! I have a question about the oil psi bypass valve.
When i dropped the motor off the oil bypass was plugged. He used a different filter plate to run it on the stand and it had a spring valve in it ( no clue what #). Before dropping the motor back in the boat i swapped them out and put my plugged filter plate back on. Ok?
I tried calling my guy but javnt heard back yet.
Full Force 10-10-2016 12:42 PM
Better off blocked off bypass then the wrong bypass, I run the 30# ones but many guys use the 11 and have issues... Blocked is fine also then it gaurantees all oil goes through cooler
14 apache 10-10-2016 12:56 PM
Get the racing filter with the bypass built in.
jeffswav 10-10-2016 12:58 PM
I use the canton racing adapter. less restrictive. Like was said either plug it or use the 30 psi valve.
Full Force 10-10-2016 01:01 PM
Racing filters don have a bypass..
Well none I know of anyway...
14 apache 10-10-2016 01:08 PM
You might want to do some research on that there are plenty of them. Some even have screens on the bypass.
14 apache 10-10-2016 01:12 PM
http://www.wixfilters.com/Speciality/Racing.aspx
cabin fever 10-10-2016 01:56 PM
Thanks. Ill leave it plugged then. I run a wix 51060r filter.
Full Force 10-10-2016 02:02 PM
Ok the ones I use do not have them...
JMPH 10-10-2016 02:47 PM
But remember there is two bypasses,one beside the centre and one below the centre, I took the two out and plugged the one to the right of the centre.
