K & N Filter And Cmi Exhaust >
Old 10-03-2002 | 09:37 AM
Default K & N Filter And Cmi Exhaust
IS IT POSIBLE TO PUT THE K&N FILTER SYSTEM AND A LESS RESTRICTIVE EXHAUST ON A 502 MPI WITHOUT CHANGES TO THE CPU SYSTEM WITHOUT HURTING THE ENGINE.
MIKE H is offline
Old 10-03-2002 | 12:29 PM
blackhawk
This is not first hand experience. But, I was told that a K & N filter and performance exhaust system will make the 502EFI run better(leaner). They are a little rich from the factory. Not much in performance gains though.
Old 10-03-2002 | 07:47 PM
liquid asset's Avatar
I've done those exact mods and ran to lean send it to Arizona speed and marine I got an oso discount cost me 300 www.azspeed-marine.com
liquid asset is offline
Old 10-05-2002 | 06:53 PM
baja 272
I'm running CMI elbow tops and the K&N with no problem at all. I didn't pick up much speed though. I was told that Merc sets them up at the factory to run rich.
Old 10-05-2002 | 11:00 PM
crmax's Avatar
if it isnt running leaner you havent made any more power, if its running to lean you can install an adjustable fuel regulator and bump up the fuel pressure till you get a good reading on your plugs
crmax is offline
Old 10-06-2002 | 07:43 AM
Ric232
I've done all of these mods, including the fuel pressure regulator (set at 48psi per Arizona Speed's instructions). What do I need to look for on the plugs to make sure I'm not running too lean?
Old 10-13-2002 | 09:57 PM
crmax's Avatar
run her at WOT then bring her bak to idle and shut her off , pull a plug it should be tan- brownish color
crmax is offline
Old 10-14-2002 | 08:11 AM
Better safe than sorry one wot run to lean could be bad news
375stinger
0
01-27-2006 07:31 PM
Pure Energy
Sonic
3
05-21-2005 06:30 AM
fountain333
01-31-2005 06:45 PM
cobra marty
07-29-2004 11:11 AM
barry
01-29-2003 02:10 AM
