I do believe I got bit by my purchase...
#102
That carb is too small for a 502. I have ran an engine lean before and it was expensive. Broke the ring landings on several Pistons. If you have a backfire at those RPMs you have a serious problem. That's why you need A/F readings or your going to ruin another engine.
#106
Ok, after further review...the BOSS says we should buy the correct cfm carb to be safe �� If that's what it takes. So there was mention of the Holley or quick fuel 800 or 850 DP's. Any other recommendations? Is it the easy way to correct or would it still need to be dialed in?
#110
I forgot what exhaust you are using, but I couldn't recommend a wideband monitor enough. Even after you get things tuned in you can keep an eye on it should something go amiss. I have a QF850 and pretty happy with it, but for not much more you can get the Holley Sniper FI. Have you considered that route?
