New 540 Combo
I did a similar build..
Ran 82 mph in my 26 Corsa naturally aspirated...
Haven't run it in a boat with the blower yet, I bought a different boat and haven't had a chance to install this engine..
N/A dyno...
https://drive.google.com/file/d/0B8O...ew?usp=sharing
Link to my build...
http://www.offshoreonly.com/forums/g...o-results.html
I read the link from your above post and did I read correctly that the OP ended up with the edelbrock e street oval port heads. 290cc. Maybe 300-305 after port work. Would like to have seen what those heads flowed after port work and assuming lager valves. I thought I read at one point he made 694 hp at 5350???? Yet dyno sheet showed 682 at 6,000 however claimed to make over 700. Unless there was another posted dyno sheet I didn't see. I will go back and read from the start 1-4. Regardless good results. Your 315's will offset the CR hp loss I would think easily.
N/A dyno...
Link to my build...
N/A dyno...
Link to my build...
Don't know yet.. I've only put about 10 hours on it in the Corsa without the blower and decided not to continue with that hull....
Bought a Velocity 290sc, Hopefully be installing the 555 before next summer...
N/A dyno...
Link to my build...
N/A dyno...
Link to my build...
You made that power with a 239/246 cam in full marine dress with EMI manifolds with an M4 and only 9 lbs boost, thats pretty good.. Maybe the 244/256 crane 651 would have been better. I don't know. You also dyno'ed that engine without the procharger as well didn't you?
With a .051 gasket, and even with the piston rock at max, you'd still have .033 of clearance. Once the piston grows, the rock will be less. If you were to average the measurement, say .018 above deck when rocked cold, and say, .012 below deck when rocked the other way, you can say, the piston is .004 above the deck, and use that for your measurment. Thats how I was taught to do it, using a deck bridge and a dial indicator. So far it seems to work.
I guess my point was why buy the heads assembled and spend more making them right, that's why I said bare, the rockers I listed are not shaft mount, still a stud mount just steel over aluminum..
Definitely, the best cylinder head guy in the state is a good friend of mine so I have no doubt that they will be right when I bolt them on. The whole idea of stud mounted rockers is a step back in time for me but at hydraulic roller pressures I don't think shaft mounted rockers are necessary. I could only find one dyno sheet with the Howards cam I'm looking at and it made right at 700hp @ 5950 rpm (more compression and smaller heads though)
http://www.chevelles.com/forums/89-e...install-2.html
