500efi Saga Continues >
Old 11-10-2016 | 07:46 PM
  #31
Picture of gasket...
https://i.imgur.com/KWzpvf7.jpg
1MOSES1 is offline
Old 11-10-2016 | 07:48 PM
  #32
Originally Posted by getrdunn
I just opened the po of the guides. Ya not good. Surprised he got them out as easily as what he did. what year are these engines? For some reason I recall GM doing something funky with guides on certain year heads etc. Still doesn't appear that really any water is going beyond the corroded erea. No trail or path of least resistance you can see.
Keep in mind you only see One side...the tips look bad on the right. Not sure if water made its way down there or lighting.
1MOSES1 is offline
Old 11-10-2016 | 07:51 PM
  #33
You'd just think there would be evidence of little water veins protruding beyond the corroded area of them.
getrdunn is offline
Old 11-10-2016 | 08:00 PM
  #34
the cast iron guides that were originally in the head have failed,using the bronze withe he salt water betw them and the cast iron is making a reaction,this will happen again.your best bet,,put cast iron sleeves back in.
sutphen 30 is offline
Old 11-10-2016 | 08:01 PM
  #35
losing compression all over the place.
Old 11-10-2016 | 08:10 PM
  #36
17046 Correct head gasket? Also how much water pressure you runner and do you run pressure relief valves?
getrdunn is offline
Old 11-10-2016 | 08:11 PM
  #37
Also are you able to check block deck surface?
getrdunn is offline
Old 11-10-2016 | 08:15 PM
  #38
few questions:
1. Are the guides shown the original iron guides? Or replacement bronze?
2. Is it your opinion that the guides are causing the water corrosion on valves, or is it something else?
3. How can you tell compression is off? Gasket is mis-shaped?
1MOSES1 is offline
Old 11-10-2016 | 08:18 PM
  #39
This is the gasket that was used: Head gasket: felpro marine 17048
1MOSES1 is offline
Old 11-10-2016 | 08:19 PM
  #40
Not easily.
1MOSES1 is offline
