500efi Saga Continues >
Old 12-23-2016 | 04:24 PM
  #61
Weren't 500 efi heads just 088s? You can find them in swap shop or pbss. I sold 2 sets this year. Expect to pay around 1k for a bolt on ready set
Crude Intentions is offline
Old 12-23-2016 | 04:30 PM
  #62
Casting number is 12562934.
1MOSES1 is offline
Old 12-23-2016 | 04:32 PM
  #63
Originally Posted by Griff
Probably Jegs or Summit
12562925 / 12562934 Service replacement head for Gen V / VI block with 7/16 accessory holes
you want this one
sutphen 30 is offline
Old 12-23-2016 | 04:36 PM
  #64
Originally Posted by sutphen 30
you want this one
Thanks sutphen. I just found one at summit. Problem is the 2.25 vs 2.18 valve stem area. Can this be machined? I wanna re-use valves.
1MOSES1 is offline
Old 12-23-2016 | 05:27 PM
  #65
934 is the same as 088.
Old 12-23-2016 | 06:45 PM
  #66
Dont reuse your valves with new replacement heads ...... False Economy.
dunnitagain is offline
Old 12-23-2016 | 06:55 PM
  #67
Originally Posted by getrdunn
Just so slightly tapered. Only one way out. If you have a good head guy he will do his best and. Cam go oversize etc. Just wonder if there is type of sealer or coating to help while installing new. Little to no clearance makes this nearly impossible but just thinking outloud.
These kind of problems eat away at me. Didn't do it before and does now type of thing. Both engines. ???
Drives a guy crazy.
I see most shop install guides with an air hammer ..... If you look in the guide bore after you remove the old guide , there is usually some deep scoring in the bore . I ream oversize with a Serdi for a round straight hole . I always heat the head to around 300 in an oven , dunk the guides in some liquid nitrogen . They will damn near
fall in , I have a mandrel that I insert in them and tap in with a ballpeen. They make product called Fluid Weld , I get mine from Goodson , stuff works great , couple drops on the guide and drive it in .
Old 12-23-2016 | 07:24 PM
  #68
Even if I replace them I will still want to keep commonality with the other engine. As I understand it replacement heads have different stem diameters. Will ask machine shop if they can be opened to be consistent with other motor. Don't want these things to be all mis matched. Same goes for push rods. Will likely have them deck it down to keep push rod lengths.
1MOSES1 is offline
Old 12-23-2016 | 07:44 PM
  #69
your talking valve diameter and yes,,these heads can be opened up to except a 2.25" valve.merc does it and so do any of us that needs to replace a hp500 head.
Old 12-23-2016 | 07:51 PM
  #70
i don,t want to sound like a debby downer BUT,if one engine needs replacement heads,why not the engine next to it that runs the same amount of hours in the same water.
mike tkach is offline
