Cam Specs
Old 11-08-2016 | 07:54 PM
Originally Posted by getrdunn
Not much info on any of those cams going past the old 525-800sc hyd flat tappet .559 lift cam that was used forever it seems.
The 800sc (not 800sci), 600sc (not 600sci), and 575sci, used the same cam. Which was a 240/240 @ .050 .559/.559 lift 110 LSA hydraulic FLAT tappet cam.
525SC, used the same 228/236 at .050 530/551 lift 114 LSA flat tappet cam, that was used in the 400hp, 420hp, and 425hp mercruiser 454ci engines.
MILD THUNDER is offline
Old 11-08-2016 | 08:05 PM
Ok Bob.... Pop quiz... What was the 850csi cam now that the op got his answer the best we can figure anyway.
getrdunn is offline
Old 11-08-2016 | 08:07 PM
I meant MT.
getrdunn is offline
Old 11-08-2016 | 08:19 PM
I dont think he got his answer yet. He was asking on the 900sc cam specs. I think the specs you gave earlier, were for the 1075sci cam.
Im so confused now lol
I think 14 apache or someone recently had some 900sc mercs in their shop, maybe they know the 900sc cam specs, or have a grind number off them?
Old 11-08-2016 | 09:05 PM
The part #'s for the camshafts, are not the same in merc's parts diagrams, so I would say, no , the 900sc carb engine, did not use the same camshaft , as the 1075 EFI.
The 900sc's were known to be valvetrain eaters. I wanna say they had something like 714 lift solid rollers. They used conventional rockers, basically old school blown big blocks like alot of us have. Nothing fancy.
Personally, If I was rebuilding a 900sc merc, I would go for a milder camshaft setup .
Joe, if I remember correctly the part # differences (in part) MIGHT be due to the various cam gears they came with but I can't remember for sure.
abones is offline
Old 11-08-2016 | 09:14 PM
and the sci engines don,t have a cam lobe for a fuel pump so the part number will be different.
mike tkach is offline
Old 11-08-2016 | 09:17 PM
I confused myself. What can I say. Anyway when I originally tried to help OP out this is where I got the info from however you very well may be right. They are however the same sutphen30 sent me recently for the 1075 cam specs. Lift and dur anyway. I did just read a thread that 900 sc was something around 714 lift SR also but again I read it I and can't actually confirm it. So let the mystery continue. Lol
getrdunn is offline
Old 11-08-2016 | 09:19 PM
Bullet will build what ever way you need it. Without fuel pump lobe with lobe. With or without dist gear. You name it. Good company.
getrdunn is offline
Old 11-08-2016 | 09:49 PM
i agree but the op still does not have his answer.i will make a call in the morning to get the answer if no one posts it sooner.
Old 11-08-2016 | 10:02 PM
Hey Mike I believe it is a solid roller 252/257 672/672 on a 112 with an Iron gear .030 hot lash, but if you can call to find out that will clear this up quickly for the OP
abones is offline
