Cam Specs
Old 11-09-2016 | 07:39 PM
  #31
Originally Posted by SB
I never understood the old school .030" lash cams. Way too much clearance.
If you are going to get a Bullet 'copy' ask them first what lash.
I ask for tight and when the cam shows up,,I look at the card for the recommended lash.
sutphen 30 is offline
Old 11-09-2016 | 08:06 PM
  #32
Originally Posted by getrdunn
How much more on the exhaust?
That was exhaust intake I set at 0 on all tight lash solid rollers cold
Black Baja is offline
Old 11-09-2016 | 08:41 PM
  #33
If setting cold u subtract .006 with aluminum heads? I always have. I know it's best to set when hot but seriously how many people really do that in real world. Especially in marine applications.
getrdunn is offline
Old 11-09-2016 | 09:42 PM
  #34
14 apache's Avatar
I would rather have a .030 lash cam and be able to catch it before zero. It don't mater tight or loose grind as long as its smooth running. My new cams are .030 from bullet.. And so post to live Recommended from MK.
Just used MK for a magnet. LOL
14 apache is offline
Old 11-09-2016 | 09:44 PM
  #35
14 apache's Avatar
Think its - .005 intake And -.007 for exhaust..
Old 11-09-2016 | 11:01 PM
  #36
Have you used the cam in discussion in an NA by chance? I've heard 540 plus engines like it but no first hand knowledge of.
Tks
John
getrdunn is offline
Old 11-14-2016 | 10:41 PM
  #37
SFOcean's Avatar
Charter Member #394
From the owner's manual;
900 SC Mechanical Valve .016 cold; .020 hot.
SFOcean is offline
Old 11-15-2016 | 09:23 PM
  #38
That throws a little monkey wrench into things. assuming it's the same cam/lobe why the .010 diff unless there is something else. Also I would think merc uses a custom crane grind vs the bullet grind. Still why the difference in lash? lobes maybe slightly different I would guess.
getrdunn is offline
