Winterizing? >
Winterizing?
Winterizing?
Old 11-14-2016 | 10:34 AM
I use pure glycol. It's red not pink and doesn't make any acid.
Black Baja is offline
Old 11-14-2016 | 01:41 PM
I did drain all the water first, Than ran 3 1/2 gallons thru each motor because everyone and there brother has bought up all the R/V antifreeze around here. Exhaust did run pink. I think I am going to have to look harder for it and do it again just for a piece of mind.
fordf350 is offline
Old 11-14-2016 | 03:22 PM
if you have the boat out of the water(I know, I have one that stays in) I would run std car antifreeze, thru it, the pink RV stuff has no corrosion fighting abilities..just flush out on hose before taking to launch, would figure most do.
ezstriper is offline
