Aluminum head valve seat material?? >
Old 11-21-2016 | 06:21 PM
Originally Posted by Full Force
i am gonna do some research the best I can to see if older AFR heads were the same I know a handful with no seat changes and no issues, not to say they can't have issues, but this nonstop spending on new heads has to stop... None of this stuff comes up until I'm already into this stuff it seems, might just go with it and roll the dice because I'm plain and simple fed up
I Have 2 sets of AFR 335 from 2009 and 1 set that are 9 months old . At 20 hrs the seats are shot in all 3 sets of heads. Switching g all of them for beryllium seats right now
billy boats is offline
Full Force's Avatar
Just talked to Bill he said same thing, he thinks it will be ok but if I wanted to run additive he said it won't hurt at all, that seat you posted looks very sunk, maybe that one was a bad casting? I am at the point I have to roll dice, already too deep into this to change now... It's not like they won't be apart next year for some f in reason lol
Originally Posted by MILD THUNDER
Tim, something Dan and I were talking about last week, was maybe a leaded fuel additive? Not sure if there is one that works, but , might be something to consider if you decide to roll the dice. I can't see it hurting anything?
Full Force is offline
Old 11-21-2016 | 06:23 PM
Full Force's Avatar
Then there my buddy cig with 600+ hours on his 600's going strong... I guess it's a 50/50 shot..
Old 11-21-2016 | 06:24 PM
Full Force's Avatar
Originally Posted by 14 apache
Don't run a solid cam if you roll the dice.
It's looking like I am sticking with hydraulic and going shirt travel, saves me lifter and pushrod cost since I can most likely keep base circle the same..
I do t have endless funds or I would do seats and solids and other things, I prefer to just run them until they break again
Old 11-21-2016 | 06:25 PM
Tim, with all the issues that you have had, I would seriously consider the seat upgrades, (yes I understand the continuing Cost issues, and truly feel for you) but also consider that when the exhaust valves begin to leak, you will increase the odds of reversion then it will snowball into more issues. I can't remember if your exhaust is wet or dry..Just another angle to consider.
abones is offline
Old 11-21-2016 | 06:32 PM
Full Force's Avatar
too late, moving forward... exhaust is dry to tip... if they break they break.... I honestly don't even care anymore...
Old 11-21-2016 | 06:45 PM
Yeah Tim I understand! I get it! Sometimes you just have to draw the line. I wish you the best, you deserve a break for sure!
abones is offline
Old 11-21-2016 | 07:11 PM
Thats a good point. When the exhaust valves start leaking , reversion is highly likely. Tim isnt running a full dry exhaust, still has rubber couplers inside the transom. Cold water on hot valves , is never good either.
MILD THUNDER is offline
Old 11-21-2016 | 07:19 PM
BUP
actually Mercruiser in the 1980's and up till the mid 90's recommended a lead substitute mixed in the gas for V-6 their engines. They sold it as well made by golden eagle up till 2001 or somewhere in that timeframe.
I am actually in favor of running a 120 to 1 of 2 stroke motor oil for marine I/O and inboards all the time. Adding lubricity to the fuel has some positives effects. On top of, I actually see fuel injectors in better shape internally from customers who use it even carbs internally have shown to be in better shape down the road (marine apps). IMO OEM electric fuel pumps in marine apps seem to hold up better as well having a bit of lubricity all the time.
BUP is offline
Old 11-21-2016 | 07:27 PM
SB
You need a comfy seat
Relax, and don't make any decisions all pizzed off.
SB is online now
