Solid roller lifters? >
Old 12-07-2016 | 09:34 PM
  #41
GPM
Originally Posted by 14 apache
I have not had that problem but I did tare the lobe face off on the lift side of the lobe that's from the stainless 2.400 intake valve.
210 on the seat would run low 6k.
And you don't think that was caused by the roller not wanting to spin because the needle bearings were hammered out.
GPM is offline
Old 12-07-2016 | 09:38 PM
  #42
14 apache's Avatar
The needles were still great the lobe could not handle the spring plus the valve. When it opend.
14 apache is offline
Old 12-07-2016 | 09:59 PM
  #43
Wasn't a bm cam? What lifters where you using when that happened? I want those kind after the abuse they or one took incl high pressures to boot and still looked great. Seriously... Was morel needle then or different lifters?
getrdunn is offline
Old 12-07-2016 | 10:09 PM
  #44
I would think the pressure against the lobe would be much greater when trying to open an exhaust valve against cylinder pressure, than opening an intake valve , even if a 2.400 ?
MILD THUNDER is offline
Old 12-07-2016 | 10:13 PM
  #45
14 apache's Avatar
Exhaust lobes were perfect the valve weighed a ton. If it was a titanium valve I am sure would not of bin a problem.
Old 12-07-2016 | 10:24 PM
  #46
14 apache's Avatar
Harold from ultra dyne camshaft and crane ultra pro lifters.
Old 12-08-2016 | 04:26 AM
  #47
There is. About 10 times more.
Black Baja is offline
Old 12-08-2016 | 04:58 AM
  #48
Even back in the day? Like say, a few years ago? I thought the crower solids had bigger wheels and fork style lifter even in the .842 diameters up till recently? I know the hydraulic crowers my buddy had bought several years back, were .750 wheel fork body. They looked like the morel. I never put them side by side on a bench to compare though.
I don't know who was making them for them back in the day. Possibly Shaver??? Johnson currently makes Bodies for Isky and Crower. They are fork style with .750 wheels. Johnson use to make lifters for Comp. Comp dropped them because they were having problems. They also use to make lifters for Scorpion. scorpion were offshore boat people. I know in the beginning they were having problems with the pile valve in the Hydraulics. The guy who built the 540's that were in my Fountain was involved in the early testing with Scorpion. Scorpion has since dropped Johnson and got out of the lifter business from what I understand. Johnson had problems and shutdown for awhile. This was years ago. If you can think back a few years. There was a time when there was a big void in the market and you couldn't get hydraulic lifters anywhere...
Old 12-08-2016 | 05:04 AM
  #49
What was the duration @.020 and @.050?
Old 12-08-2016 | 05:07 AM
  #50
Hey Tim what were your .020 and .050 duration numbers on your cams???
