Has anyone ever... >
Has anyone ever...
Has anyone ever...
Old 10-06-2002 | 09:13 AM
DanB's Avatar
Charter Member #71
Default Has anyone ever...
has any one ever experienced a 30* increase in oil temp and excessive blow by when switching from synthetic to regular motor oil? Water temp remained the same. Am I just burning off the remains of the synthetic???
Dan
DanB is offline
Old 10-06-2002 | 09:23 AM
Audiofn's Avatar
Charter Member #232
I would buy the temps going up a bit. The blow by seems odd... Isnt non synthetic oil ussually less likely to do that?
Jon
Put your best foot forward!
Audiofn is offline
Old 10-06-2002 | 09:25 AM
what oils are we talking about??
audacity is offline
Old 10-06-2002 | 10:15 AM
DanB's Avatar
Charter Member #71
switched from Royal Purple racing 40 to Valvoline 50 wt racing
DanB is offline
Old 10-06-2002 | 11:31 AM
Mr Gadgets's Avatar
Charter Member #601
Dan,
I went the other way..from Valvoline 20-50 to the Royal Purple.. didnt see any changes that I can relate. I see oil temps from the pan around 260/270 when running hard..
Dick
Mr Gadgets is offline
Old 10-06-2002 | 11:35 AM
WHY...go back...unless u change it a lot more often due to price??? the Val **** has a lot more zink content for metal to metal.
audacity is offline
Old 10-06-2002 | 11:51 AM
DanB's Avatar
Charter Member #71
I switched for several reasons...not available..breaking in new distrib gear..temps were too low.. never got hotter then 200 even when running hard..mostly 150 or so.
Now temp is 230 at 3500-4 rpm
pressure is good
water 150-160.
Also timing was way advanced which would cause hotter temps???? Also may have over filled it...12 qt pan..I put in 12 qts..usually run 10
Backed it down to 35* after a short run. Power is still good. What conserns me is the blow by
DanB is offline
Old 10-06-2002 | 12:22 PM
actually retarding the timing can account for higher tmps. and merc runs 190 deg for oil..
audacity is offline
Old 10-12-2002 | 01:02 PM
DanB's Avatar
Charter Member #71
Well
It was the oil I guess
Re placed the Valv with more Royal Purple and all is right with the world again. I cant figure this one out...but who cares???
Thanks for the input fellas
Dan
DanB is offline
Old 10-12-2002 | 01:58 PM
I too used Valvoline once and had major oil consuption...switched back and all was fine.
Back4More is offline
