Premature main engine bearing failure mystery >
Old 01-01-2017 | 11:44 AM
  #71
so.. first of all where are you taking your oil temp reading? at filter head or from the cooler? what is your main bearing clearance and who's bearing are you using? this may have already been answered but I'm not backtracking thru 7 pages of posts to find it lol...
main bearing clearance when using thick oil (25/40, 20/50, etc) must be significant.. in other words enough clearance to allow the oil to do its work...
adk61 is offline
Old 01-01-2017 | 01:20 PM
  #72
Originally Posted by Tinkerer
I ran 509's at 650 HP with stock Merc oil lines and acc. with NO oil flow problems. This was the larger cooler ( 3 inch dia.) and hoses that come on the 502 HP.
And WHY is anyone with a non stock engine running the oil bypass. I removed, tapped and plugged mine.
ALSO
90 hrs X 50 MPH = 4500 miles
since when
most cars at 50 MPH are at 1500 RPM.
Boats cruise at 3500 RPM at 50 MPH
At 3500 a car would be at or above 100 MPH
Lets see you run your car at 3500 RPM for 90 hours and see how it lasts.
A nickel works fine also. Ha. Also BB touched on it it think however is it possible raw water pump has an impeller ready to go an maybe not pumping enough cool water through the engine causing to heat up...
getrdunn is offline
Old 01-01-2017 | 01:31 PM
  #73
Oil temp sensor is in the remote filter housing, before the filter and before the cooler. Bearing clearance was built at .0025. Build sheet doesn't list the bearing mfgr., I'll find out when I talk to him this week.
ctuck0659 is offline
Old 01-01-2017 | 01:37 PM
  #74
ALSO
since when
I'm not familiar with the lines, block adapter etc used on the 502HP. I was using the adapter, lines (3/8" id) and cooler (2X12") that are std. on the Merc stock 502 black motor. I quickly upgraded to a 3X18" cooler but continued to use the stock 3/8" id lines until a couple of months before I pulled the eng's.
Old 01-01-2017 | 06:24 PM
  #75
Tinkerer's Avatar
Mine came with the 3 X 18 oil cooler stock. 1992 Merc. 502 Magnum ( HP ) 385 HP. I did a little bit of work and changed a few parts to get 650 HP - Those engines are still running in another s boat.
Tinkerer is offline
Old 01-01-2017 | 07:16 PM
  #76
Full Force's Avatar
rods or mains? both? and I can tell you right now if your running 20-50 thats too tight, especially at the back of the engine...
rods would be fine, mains will eventually have issues, if running 20-50..
Full Force is offline
Old 01-01-2017 | 08:10 PM
  #77
rule of thumb is .001 per inch of journal dia for standard engine,bigger for more power..0027 for rods .0033 for mains makes me happy on a bbc.a little more is ok if the rest of the oiling system is correct.edit in,my honda accord uses 0w20 synthetic,when i looked up the bearing clearance on the v6 engine i almost chit my pants.
mike tkach is offline
Old 01-01-2017 | 08:26 PM
  #78
14 apache's Avatar
Let me guess. .0008-.0012
14 apache is offline
Old 01-01-2017 | 08:31 PM
  #79
SB
The 0W-20 synthetic motors seem to last longer with 5W-30 synthetic....in my experience...can't vouch for others.
SB is offline
Old 01-01-2017 | 08:45 PM
  #80
i think i will go with 5w20 in the summer and stick with the 0w20 in the winter.it currently has 70 k on it.i change it every 5 k.my neighbor used 5w30 in his honda pilot for years and it called for 0w20.who knows if it really matters?i sure don,t.
