Bandit motors >
Bandit motors
Bandit motors
Old 01-04-2017 | 06:10 AM
  #41
SB
Originally Posted by endeavour32
So here is the Dyno sheet. Looks like a 651 cam, pro 1 310 heads, sniper jr intake. 1050 carb. No idea if it's a 4150 or 4500, due to the jets im guessing 4150. Either way, Dyno sheet guys, is this a happy Dyno or using a realistic correction factor?
I ran the #'s at 6300rpm. The correction factor added 50hp, (sheet shows 696.6hp , actual power measured was 646.12hp) which is +8% correction. Sheet also shows the same "C.F. 1.08 "
So, one would have to find altitude of shop and air conditions going into engine that day to see if this is correction is high or not.
Any correction this high raises doubt and further investigation, as noted above, would be needed to accept these #'s as true or not.
SB is offline
Old 01-04-2017 | 06:32 AM
  #42
Full Force's Avatar
That's why gps is best test lol
Full Force is offline
Old 01-04-2017 | 08:04 AM
  #43
They actually talk about a 38 cig I think it was. Had 575s. They built some of the 510/700s and boat picked up 10 mph. Without knowing anyone personally that sounds good
Crude Intentions is offline
Old 01-04-2017 | 08:14 AM
  #44
Yes, it was a stepped Top Gun.
Its nice to have engines built by someone who understands the powerband thats required to make a boat go fast. A guy with a twin step top gun, probably isnt concerned if his boat takes 2 seconds longer to get to top speed. He is probably more interested seeing a higher top speed number when hes wringing it out for miles and miles in a poker run.
But those big torque numbers from 3000-4000 makes for nice dyno sheets and discussion on what "exemptlatlory examples of engine efficiency and unicorn like gobbledygook stellar induction package " ...meanwhile, your boat is a turd on the water.
MILD THUNDER is offline
Old 01-04-2017 | 11:35 AM
  #45
I looked up their address and due to their location, I'm giving them at best 15' above sea level. I also looked up the weather at their location on the time stated on the sheets and I'm showing 60 degrees, and a barometric pressure of 29.92". Seeing that they are showing this was done at 2am the temps would be pretty sable.
endeavour32 is offline
Old 01-04-2017 | 11:41 AM
  #46
After getting the build sheets on theses the carb used was an AED spec'd Dominator.
Old 01-04-2017 | 12:07 PM
  #47
14 apache's Avatar
Friday, July 15, 2016
« Previous Day
Next Day »
Daily Weekly Monthly Custom
Actual
Average
Record
Temperature
Mean Temperature 78 °F -
Max Temperature 82 °F 78 °F 93 °F (2010)
Min Temperature 73 °F 65 °F 61 °F (2000)
Cooling Degree Days 12
Growing Degree Days 28 (Base 50)
Moisture
Dew Point 65 °F
Average Humidity 64
Maximum Humidity 79
Minimum Humidity 52
Precipitation
Precipitation 0.02 in - - ()
Sea Level Pressure
Sea Level Pressure 29.91 in
Wind
Wind Speed 12 mph (West)
Max Wind Speed 16 mph
Max Gust Speed 20 mph
Visibility 10 miles
14 apache is offline
Old 01-04-2017 | 12:10 PM
  #48
14 apache's Avatar
Hourly Weather History & Observations
Time (EDT)
Temp.
Heat Index
Dew Point
Humidity
Pressure
Visibility
Wind Dir
Wind Speed
Gust Speed
Precip
Events
Conditions
12:53 AM 79.0 °F - 64.9 °F 62% 29.85 in 10.0 mi SSW 11.5 mph - N/A Clear
1:53 AM 75.9 °F - 68.0 °F 76% 29.85 in 10.0 mi SW 11.5 mph - 0.02 in Overcast
2:53 AM 75.9 °F - 66.9 °F 74% 29.84 in 10.0 mi SSW 12.7 mph - N/A Clear
3:53 AM 75.0 °F - 66.9 °F 76% 29.85 in 10.0 mi SW 12.7 mph - N/A Clear
4:53 AM 75.0 °F - 66.0 °F 73% 29.85 in 10.0 mi SW 13.8 mph - N/A Clear
5:53 AM 73.0 °F - 66.0 °F 79% 29.87 in 10.0 mi SW 12.7 mph - N/A Scattered Clouds
6:53 AM 73.0 °F - 66.0 °F 79% 29.90 in 10.0 mi SW 12.7 mph - N/A Mostly Cloudy
7:53 AM 75.0 °F - 64.9 °F 71% 29.91 in 10.0 mi WSW 11.5 mph - N/A Clear
8:53 AM 77.0 °F - 66.0 °F 69% 29.92 in 10.0 mi WSW 12.7 mph - N/A Clear
9:53 AM 79.0 °F - 64.9 °F 62% 29.93 in 10.0 mi WSW 9.2 mph - N/A Clear
10:53 AM 79.0 °F - 66.9 °F 66% 29.93 in 10.0 mi West 12.7 mph - N/A Scattered Clouds
11:53 AM 82.0 °F 83.1 °F 63.0 °F 52% 29.93 in 10.0 mi West 16.1 mph - N/A Mostly Cloudy
12:53 PM 81.0 °F 82.5 °F 64.0 °F 56% 29.93 in 10.0 mi WNW 15.0 mph - N/A Mostly Cloudy
1:53 PM 82.0 °F 83.4 °F 64.0 °F 54% 29.92 in 10.0 mi WNW 15.0 mph 19.6 mph N/A Clear
2:53 PM 81.0 °F 82.2 °F 63.0 °F 54% 29.93 in 10.0 mi WNW 16.1 mph - N/A Clear
3:53 PM 82.0 °F 83.1 °F 63.0 °F 52% 29.94 in 10.0 mi WNW 13.8 mph - N/A Clear
4:53 PM 81.0 °F 82.2 °F 63.0 °F 54% 29.94 in 10.0 mi WNW 13.8 mph - N/A Clear
5:53 PM 80.1 °F 81.5 °F 63.0 °F 56% 29.93 in 10.0 mi WNW 10.4 mph - N/A Clear
6:53 PM 80.1 °F 81.7 °F 64.0 °F 58% 29.91 in 10.0 mi WNW 5.8 mph - N/A Scattered Clouds
7:53 PM 78.1 °F - 63.0 °F 60% 29.92 in 10.0 mi West 3.5 mph - N/A Mostly Cloudy
8:53 PM 77.0 °F - 64.0 °F 64% 29.94 in 10.0 mi NW 8.1 mph - N/A Mostly Cloudy
9:53 PM 75.9 °F - 62.1 °F 62% 29.95 in 10.0 mi North 8.1 mph - N/A Mostly Cloudy
10:53 PM 73.9 °F - 63.0 °F 68% 29.97 in 10.0 mi NNE 9.2 mph - N/A Mostly Cloudy
11:53 PM 75.0 °F - 63.0 °F 66% 29.99 in 10.0 mi ENE 4.6 mph - N/A Mostly Cloudy
Old 01-04-2017 | 12:12 PM
  #49
14 apache's Avatar
Weather History for KBKL - July, 2016
Old 01-04-2017 | 01:02 PM
  #50
[QUOTE=14 apache;4515943]Friday, July 15, 2016
Wrong time period- The date was May 31, '12. If the time is right, it looks like 2:36 am. I looked this up too, I appears that the info on the sheets was good in regards to the weather.
