Hull issues
Old 01-02-2017 | 07:07 PM
Originally Posted by I.C.U.Lookin
The 24 bravo 1 gives you 12% slip. That's pretty good.
Try putting in 23.2 for the slip calculator, since thats what a 24 bravo measures out to be about. Slips even lower.
I'm with you, I think he's down on power. Whats the build specs?
MILD THUNDER is offline
Old 01-02-2017 | 07:09 PM
Yes. That's the direction I was headed is his power is off. Not an issue with the notch.
Crude Intentions is offline
Originally Posted by MILD THUNDER
Your slip is good. Sounds like your not making 600hp.
beat me to it,,my guess,,540-550hp
how about some info on the engine.
sutphen 30 is offline
5500. 599 hp
4700 592 tq
dspad is offline
Old 01-02-2017 | 07:12 PM
509 stock gen 6 block
Merlin iron heads 320
Merlin intake single plane
850 qf
243 248 630
Dry risers
Harden exhaust manifolds
9:1 compression
Je mini dome pistons
H beam rods
dspad is offline
Old 01-02-2017 | 07:17 PM
With that cam, not surprised its going faster with the smaller prop. Try a 22p bravo one.
Where did the HP peak ?
Also is the hull stepped or not?
Old 01-02-2017 | 07:19 PM
Then let's go to the dyno. What exhaust on the dyno and what exhaust in the boat. You can easily leave 40 or more from dyno headers to marine manifolds.
Old 01-02-2017 | 07:22 PM
Stepped hull
Harden cast aluminum manifolds
Dry risers wet at the tip
dspad is offline
Old 01-02-2017 | 07:23 PM
Dyno headers. When on dyno
dspad is offline
