Hull issues
Old 01-02-2017 | 07:24 PM
Yea the notch is not a problem. If you do fill it your drive height will be way off also.
indysupra is offline
Old 01-02-2017 | 07:25 PM
Peak hp was at 5500 599. 6000 hp was 592
dspad is offline
Old 01-02-2017 | 07:27 PM
Was it dynoed with your exhaust or dyno headers? Do you have dyno sheets?
Crude Intentions is offline
Old 01-02-2017 | 07:31 PM
This is a hydraulic motor
dspad is offline
Old 01-02-2017 | 07:32 PM
Drive is 2.50 below the hull pad
dspad is offline
Old 01-02-2017 | 07:34 PM
Also with dyno headers to your manifolds is a dramatic loss. Mild thunder will chime in again but I think mer recently did a test on similar power and it was around 40hp from dyno headers to manifolds.
Old 01-02-2017 | 07:38 PM
Harden makes a tubed headers called cyclones that will work with my risers that are all stainless
Basically my manifolds are the same manifolds that came
On HP 500s or Gil type manifolds which I read somewhere rated for 500 hp I'm wondering if they're choking me out
dspad is offline
Old 01-02-2017 | 07:44 PM
Yes. I know the ones you have. GIL replicas. As far as manifolds go the best ones are the ones diamond sells. The old KE design. I'm in the same department. I have gils for my builds and now second guessing myself.
Old 01-02-2017 | 07:45 PM
On HP 500s or Gil type manifolds which I read somewhere read it for 500 hp I'm wondering if they're choking me out
I dont think youll see a gain from the short tube cyclone/gil replacements.
I think the heads are probably your limiting factor from keeping it how a 27 fever should run with 600hp. Legit 600hp.
MILD THUNDER is offline
Old 01-02-2017 | 07:49 PM
Okay which heads I run in salt water but flush all the time
dspad is offline
