Blower surge Make it stop
#31
MT thanks for posting the videos very cool. So if I start to back them out at 850 @ 10* it will take off and surge as soon as I touch the first idle air bleed an 1/8 of a turn. It is way sensitive big time. This is the issue Ive been having with it. There is no curve the distributors are locked. So when I back it down to ten thats all the timing all the way as you would know!
Those 830 holley double pumpers, are like most double pumpers. They were designed for race cars, with big cams, and poor idle vacuum. So they opened the idle feeds up a bunch, to compensate. You are running TWO of them, atop an engine, with a fairly mild camshaft. There lies your problem.
Before we go nuts. Try this. Close the rear mixture screws off completely . On the secondary side on both carbs. Try using only the front ones.
Also, make sure your floats aren't too high. The higher the float level, the more head pressure you get, which will push even more fuel thru the restrictors, making this even worse. I lowered my floats down to where they needed to be this summer after my first ride last summer. They were a bit high. Just by lowering the floats, my Air fuel ratio at idle, went from 11.5, to 13's, without even touching the mixture screws.
#32
Those 900's idled like 454 mags around the docks
nice exhaust you have there on your run stand btw. Those stellings or CMI?
#34
Although, I don't think 900rpm, should be an issue for a bravo drive. Im not super up to speed on the bravo stuff, so maybe someone else can chime in
#35
Registered User
MT that is one thing I thought about trying ( closing off the secondary idle screws )and havent yet but I will. Those Idle feed restrictors look small I haven't put my # sizers in them yet to see what size they are? Have you had any experience with moving the restrictors to the top of the tube inside? Ive read that helps with the emulsion in the tube??
#38
Registered User
Transmissions. We don't have bravo's.
Must be an east coast thing ( Transmissions ) LOL!
