Will carb need rejetted? >
Old 01-16-2017 | 05:52 PM
fourplaydave69's Avatar
Default Will carb need rejetted?
In late fall switched to Edelbrock aluminum heads from stock iron heads on 540. Will these lean the motor out much? Have all winter to worry about it. Thanks
fourplaydave69 is offline
Old 01-16-2017 | 06:26 PM
Probably not much. The edelbrocks don't flow much better than the stock Iron rectangles. Still good to check though.
MILD THUNDER is offline
Old 01-16-2017 | 06:44 PM
Ouch.... I wouldn't imagine either unless your did more than a heads swap. what kind of exhaust you have. If possible try and get an afr 02 over the winter. Best investment you'll ever make. Chambers same size as your old cast heads?
getrdunn is offline
Old 01-18-2017 | 01:18 PM
Chambers the same size. Running Lightning Headers. Dropped valve seat out of recond. iron heads.
Old 01-18-2017 | 05:21 PM
I ran lightenings when they were 1050.00 a set new. Loved them. They sound extremely nasty. At time had a sound all of their own. Back to your jetting though I think you'll be fine. I strive for best possible jetting no matter what it takes. Black plugs and carboned up pistons is unexceptable.
getrdunn is offline
Old 01-18-2017 | 08:26 PM
I'm just curious why you thought that your jetting was spot on before?
Baja Rooster is offline
Old 01-19-2017 | 04:17 AM
When the motor was built ,it was dynode.
