Trim Tabs quesitons >
Trim Tabs quesitons
Trim Tabs quesitons
Old 01-24-2017 | 03:11 PM
Default Trim Tabs quesitons
Let me start by saying this is my first boat of any kind and it does not have trim tabs on it. I have not had my boat out yet so I do not know how it currently handles. It is a 30ft advantage deep V with a single outdrive. I have read on the subject but wanted to hear what some of you might suggest for size or if I even need them. Is there something particular I should be looking for in the handling of the boat that would suggest I need these or would they just be an upgrade to the boat? There also seems to be a big difference in materials and costs as well but would assume a billet version would be preferred, but open to see what peoples experiences are? This will mainly be a Lake Tahoe boat so it will need to handle some decent swell at times
thanks
Scott
Tahoe540 is offline
Old 01-24-2017 | 03:35 PM
Tabs aren't necessary. I have owned boats with out them. They are beneficial. They can help with the attitude of the boat as far as keeping bow up and down. Also on plane if the weight is not evenly distributed instead of asking people to switch sides you can correct easily with tab.
Crude Intentions is offline
Old 01-24-2017 | 05:42 PM
Nothing wrong with above post but I wouldn't consider having a boat without. Reasons listed above.... some boats have a tendency to porous etc at various rpm's and speeds. Tabs help with that also without having to tuck your drive all the way in. I had 28 saber with a single and couldn't imagine not having tabs. 280's perfect. Just my opinion.
getrdunn is offline
Old 01-24-2017 | 05:45 PM
I hate when boat runs like a Driver in Detroit behind the wheel of a 225. The Detroit lean. Lol
getrdunn is offline
Old 01-24-2017 | 08:13 PM
My Baja 260 did not have any tabs when I got it. I pieced together a set of K-planes mostly from parts on ebay for a reasonable cost. Now, I couldn't imagine having the boat without them. They can really help getting on plane and help take some bite out of the bigger waves. I am adjusting mine all the time because I usually have a bunch of people with me and they never stay still.
Heyglenn is offline
Old 01-25-2017 | 08:21 AM
Thanks for the responses guys, this is the kind of information I was looking for. Now I do see why the billet ones are more expensive and they do look much nicer than say the steel sheet metal ones. I would probably just save up and get a good set but does anyone have any experience with these http://www.lencomarine.com/index.php...gh-performance?
Tahoe540 is offline
Old 01-25-2017 | 09:41 AM
Dave M's Avatar
Veteran: Navy
I would definitely want tabs on a 30' performance boat, or any boat for that matter.
I had 280's on my 24 Superboat and 380's on my 30' Super.
I have these tabs http://www.lencomarine.com/index.php...abs/heavy-duty on my 30' center console. After having k-planes on my previous boats I was skeptical about these tabs. But I have to say they get the job done.
Dave M is offline
Old 01-25-2017 | 10:08 AM
rak rua's Avatar
Drive it, get used to it and enjoy it before spending more money. It's real easy to spend money on these things and you never get it back. Just learn a bit more, mix with other boaters and let someone else drive, see what they think.
There are still some manufacturers who don't put tabs on everything, I don't think the 29 Active Thunder has tabs does it? Never read a negative comment on any AT. Just hold off for a while, you can always do it next season if nec.
Congrats on the purchase!
RR
rak rua is offline
Old 01-25-2017 | 02:29 PM
Call Bob Sepulvada at Advantage boats. I bet he will tell you that there is no benefit to tabs on most of their hulls.
snapmorgan is offline
Old 01-25-2017 | 03:21 PM
Thanks for the info, my plan is to take it out without before I do anything. Thanks for the input will have to wait till spring to try it out, but at least we should have plenty of water with all this snow we got in the Tahoe area
Tahoe540 is offline
