another cam thread
i am building a 454 for a 1969 chevelle,it currently has the origional 325 hp 396 and it is going to be removed and put away as a complete engine except for the starter&alternator.i was searching for parts for the short block and found from an oso member who i won,t mention his name but i am hoping he will chime in on the thread.this member had a gen 5 or 6,i can,t remember for sure for sale so i contacted him,the guy who owns the car did not want to go with a electric fuel pump so the late model block was not going to work,he mentioned that he had a mark 4 454 4 bolt short block that he built about 6 years ago and it sat in a unheated shed for 6 years and had some rust.he took it apart and texted me a bunch of pictures and the rust did not look to bad so myself and the car owner went on a 6 hour road trip.upon inspection of the parts i decided that i could clean it up and reassemble it so we struck up a deal and loaded everything up and i brought it to my shop,i sprayed everything down with my favorite oil[MARVEL MYSTERY OIL]and shoved it in the corner.a few days later i got after it with more marvel and a scotch brite pad and it was working good,to the point that one would never know it had rust.today i ordered a set of afr 265 ovals for it and started thinking about a cam.i am going to go with a hyd roller and have one in mind.i would like to hear from the usual suspects on oso about what they would pick for a cam and see who comes closest to what i am thinking about using.who ever comes the closest to the one i have in mind is going to win a prize.let,s have some fun with this fellas.
Compression?
Stick ? What ratios
Auto ? What converter What rear gear ? Compression ? PB's ? What does he want out of car ? Mild, crazy, doesn't care but just wants some dumb lope for cruise's ? Ah comeon,I'm gonna stop with questions...you know the drill. You just forgot to mention it all...lol |
Originally Posted by SB
(Post 4523655)
Stick ? What ratios
236/242 .600" lift or so, and 110LSA. It will do all things well but not one thing great....other than smoking the hides aslong as he wants when he dumps the clutch.
230/236 110 will be fine too. I would not go lower than this though...just because. I'm assuming good exhaust system. Psst: The way I drive, I'd be going 240 or so at .050" and prob 109 LSA. |
Lunati HR
Advertised Duration (Int/Exh): 282/290 Duration @ .050 (Int/Exh): 231/239 Gross Valve Lift (Int/Exh): .600/.600 LSA/ICL: 110/106 |
No one asked what he wants/or can spin this engine to? Assuming 6000?
Im a muscle car purest and If the starter and alt are date code correct for the 396 then leave them on the engine and buy new, as far as cam, I would make it 3/4 race the 7/8's race lobe profile is all wrong :helmet:
We just put a 238 / 242 @.050 on a 109 LSA with just under .600 lift in my 440.
Good flowing cast iron ported heads. Flat tappet tight lash mechanical with EDM lifters. If he wants it to sound killer at the ice cream shop, tighten up the LSA. :coolcowboy: |
3/4 cam, solid roller
Comp Cams custom billet HUC hyd roller with iron gear 410 bucks and at your door in a week. :)
239/247 109 LSA 106ICL .621/632 |
Originally Posted by vintage chromoly
(Post 4523732)
Originally Posted by Sonic30ss
(Post 4523761)
Sounds like the old Direct Connection Purple Shaft .590 cam nice and lumpy :)
Kinda torn between 222-230 .576-.598 110 LSA an 226-234 .587-.610 112 LSA. Not overkill by any means but should be very streetable and fun.
Mark |
This
Lunati 20110712 - Lunati Voodoo Camshafts Camshaft, Hydraulic Roller Tappet, Advertised Duration 282/290, Lift .600/.600 |
Originally Posted by snapmorgan
(Post 4523816)
This
(Post 4523816)
This
(Post 4523816)
This
Originally Posted by MILD THUNDER
(Post 4523748)
Originally Posted by getrdunn
(Post 4523673)
Lunati HR
Originally Posted by mike tkach
(Post 4523833)
did you run this in your program?only looking to spin this engine to 6000 rpm.
I think she might have 600hp in it with that combo. Did you get the cnc chamber option? |
yes.imo well worth the money.
Fwiw. The intake valve closing point, is prob the #1 player in a cams power curve. The valves closing point can change with ICL .
109 LSA with 106 ICL= 45* intake close. Pipe max says good for 5931RPM 112 LSA with 109 ICL = 48.5 * intake close. Pipe max says good for 6161RPM 114 LSA with 110 ICL = 49.5 * intake close. Pipe max says good for 6238RPM A change in LSA, or really ICL, can change the powerband, even though the .050 duration, doesn't change. Looking at almost 300rpm there. A 222* intake lobe, with LSA of say 110, typically having a ICL of 106, would close the intake valve at 37*. Pipe max says good for 5277RPM. (makes sense when you think about it. A 454 Magnum, has a 224 intake lobe, with 115 LSA, and is done around 5200. A tighter LSA cam, will peak sooner typically bc the intake valve closes sooner) A 231* intake lobe, like that Lunati Snap suggested, having a 110 LSA and 106 ICL, has an intake closing of 41.5*. Pipe max says good for 5623RPM. I know an OSO member, who has 454's with 308 Darts. 230/235 ish madera cams. 9.2:1, 850 carb, victor jr intakes if I recall. Made 530hp and was done at 5300ish on the dyno. He's installing bigger cams currently. |
(Post 4523850)
Keep in mind he said it had power brakes. That means 18" vacuum at idle for them to work properly. Really limits cam selection. I just fought through this on my Cobra replica with stack injection. Ended up adding a vacuum pump from a diesel pickup to solve it.
Originally Posted by sutphen 30
(Post 4523817)
How about a ZL1/L88 427 mechanical flat tappet
262/272 110 LSA https://www.youtube.com/watch?v=lDfM35SVRk0 |
Or a stock cam from a 1970 LS6 454 Chevelle . Hyd flat tappet
242/242 @ .050 .520/.520 lift 114 LSA Whats with this 222* crap? Are we building an engine for mom's wagon, or we gonna make some noise and bang some gears? :coolcowboy: |
(Post 4523885)
Mike, I never recommend cams these days but I can tell you what I run in my 396 69 Camaro. custom comp grind solid roller, 263/274 648/646 109 lsa, 49* overlap, 25/25 lash, 12.5 CR 7/16 push rods comp rller rockers, through cambered exhaust. won't really work for your build, But if your customer wants to rattle the glass at the soda shop that's the ticket!!
The GM crate 427/480HP engine, is 10:1, uses the same 224/234 110 LSA the ZZ502 crate engine uses. The 427 makes 480hp around 5800rpm. The ZZ502, makes 508hp at 5200rpm. Same heads, same cam, 9.6:1.
Im almost positive that cam is a BILLET core, and availble for 200 bucks new Camshaft Type (P/N 12366543) |
Originally Posted by abones
(Post 4523903)
(Post 4523904)
(Post 4523885)
262/272 110 LSA https://www.youtube.com/watch?v=lDfM35SVRk0 I'm sure power was left on the table compared to a modern roller but I wasn't too concerned with that, besides have you ever heard one of these cams? |
(Post 4523905)
Bet that thing sounds sweet. What about the vette cam? :)
I think we all must have a sickness taking engines on a Saturday night! |
(Post 4523907)
I have a new one in my stock that I will sell cheep if you want it Mike!!! Good call Mild!! that cam would be high on my list!
Originally Posted by Lee
(Post 4523909)
GM 3959180 2nd design L-88, ZL-1 cam, also used in the LS-7. I'm just finishing up on my street car and found a NOS GM one that I used with Crower EDM lifters.
I'm sure power was left on the table compared to a modern roller but I wasn't too concerned with that, besides have you ever heard one of these cams? FYI: Check those crower EDM lifters real closely! I just bought a set last spring / late winter and one was absent the EDM hole. I had to send it back and get a replacement. Probably just a fluke, but just a heads up. |
I usually do this...1800-cam-help..comp, grinding me a special SB cam as we speak for boat engine I'm doing now
after doing some research i decided to go with a crane 168741 cam.in this small 462 cu in engine i think it will pull hard to 6400 or so and still have more low end grunt than the car can use.the heads came today and i gotta say they are a thing of beauty.the polished cnc chaimbers look awsome.
| All times are GMT -5. The time now is 12:51 PM. |
