Timing set for gen v block with step nose cam >
Old 02-08-2017 | 12:07 PM
peek on ebay item # 360766837510 GM kit
I'CE is offline
Old 02-08-2017 | 01:46 PM
Had anybody use the SA Gear Gen 6 billet double roller? Is state's it will fit the stock cover.
Baja8808 is offline
Old 02-08-2017 | 06:17 PM
http://www.competitionproducts.com/H.../#.WJuzT_LLqCs
That billet set, will fit under the stock GEN 6 timing cover. Has the good German made chain as well.
Was recommended by Eddie Young. Apparently the Rollmaster chains, may require some grinding of a stock GEN 6 timing cover, where as those, do not.
But, being you have a GEN V, fitment shouldn't be an issue.
Last year I replaced both my cloyes sets, with Rollmasters. One of the cloyes sets, had an IWIS chain, like the rollmasters. The other, did not. The IWIS chain was still nice and tight, the other, had what I considered, a good amount of slop, for not a ton of time on it.
After seeing some guys have issues breaking cam sprockets, I will always use a billet set from now on, esp if the spring pressures are over 400lbs open. I think they are worth the money. jmo
MILD THUNDER is offline
Old 02-08-2017 | 11:14 PM
Yes definitely going billet, open pressure is set at 432 lbs. Did you use the red or gold series rollmaster?
Baja8808 is offline
Old 02-08-2017 | 11:49 PM
bck's Avatar
bck
Charter Member#568
I think I might have an unused rollmaster red if you were thinking of getting one. Have to check. It'd be a CS 2090 iirc
Straight bottoms and flat decks
bck is offline
Old 02-09-2017 | 08:32 AM
As mentioned, this is a really nice set. It's the same billet gears as the Rollmaster set, but uses a Roll-on German made chain instead of the IWIS. The issue I've seen with the SA Gear set is the chain. It has some nice billet gears, but the chain is an import. They don't seem to stretch or break, but some of the links get sticky over time. It doesn't want to move smoothly.
The Comp Products set is a great alternative to the Rollmaster set for a little over half the price and doesn't require any clearance work to fit.
Eddie
Young Performance is offline
Old 02-09-2017 | 01:49 PM
Do you have 2 sets? I need 2 for twins.
Baja8808 is offline
Old 02-09-2017 | 03:57 PM
bck's Avatar
bck
Charter Member#568
I should be able to check tomorrow. I should have 1, I might have 2. Look into whatever these guys are talking about with the clearance and make sure they'll work for you. Give me your email or phone and I'll send you the pics and info
bck is offline
Old 02-11-2017 | 08:15 AM
Ok thanks, send it to [email protected]
Baja8808 is offline
Old 06-19-2018 | 01:28 PM
Ok I'm looking for a timing set for my gen 5, 525SC rebuild and after some research it looks like the following are recommended:
1) Roll master CS2040 -$122
2) Howard's 94309. $97
3) Cloyes. ??? $???
4) the comp one MT listed above but the link is broken and no part number
i also had my mains alighn-honed but I don't trust the work so I'm not sure how to verify if I need a shorter timing set or just a standard.
Which set is best to run?
Mohavvalley is offline
