Timing set for gen v block with step nose cam >
Old 02-07-2017 | 09:06 PM
Default Timing set for gen v block with step nose cam
What timing set can be used on a gen v block with a step nose cam? The cover is stock 525sc gen v.
Baja8808 is offline
Old 02-07-2017 | 09:30 PM
you need a timing set for a gen 6 engine,also need the cam retaining plate&blots.i have the part number for them in the shop and can post in the am unless someone beats me to it.
mike tkach is offline
Old 02-07-2017 | 09:54 PM
I have the retaining plate and bolts. Just need timing set. Is the gen vi a single or double row?
Baja8808 is offline
Old 02-07-2017 | 10:11 PM
Full Force's Avatar
If you buy rollmaster with Torrington bearing you need to clearance the retainer... just fyi
Full Force is offline
Old 02-07-2017 | 10:49 PM
not if you have the right ratainer,i found out their are two sizes.
Old 02-07-2017 | 10:53 PM
factory one is slngle.i like the rollmaster.cloyes also has a nice one,here is a tip,the summit brand is a cloyes and a little cheaper price.i recently took an engine apart that was built in 09,i could not believe how tight the gm single row chain was.
Old 02-08-2017 | 06:25 AM
Full Force's Avatar
Oh yea? Never knew... that's good to know. Wish I knew that when I pulled my hair out way back when lol
Old 02-08-2017 | 10:32 AM
Panther's Avatar
Frank's Marine Service
Was gonna say... never been an issue for me!
I like the Rollmaster Gen VI as well!
Panther is offline
Old 02-08-2017 | 10:48 AM
Full Force's Avatar
I was not the only person to find out there was an issue at the time, made a post seems many had same issue, part of learning curve
Old 02-08-2017 | 10:49 AM
The chain looks like a drive chain off a motorcycle... serious rugged chain!!
adk61 is offline
