Rigging/plumbing things
#31
The bypass system is almost a must have on cammy lightweight jets.these pull water out of the jet pump bowl and can deliver over 50 psi on the cooling system side causing burst hoses and intake gaskets .
Baffle inserts work better on those too ,with some water dump management.Did run a similar system on a zz502 with cmi headers that was running a sherwood trs style pump ,headers got quite warm to the touch but never cracked , plus it sounded better at idle lol.
Never had a hint of reversion ,even with the long local no wake zones.
