low compression 548 dyno testing has begun!! >
Old 03-30-2017 | 02:39 PM
  #261
bck's Avatar
bck
Charter Member#568
No big deal.Just making sure. I haven't sent the final ones yet due to a scanner issue. Save time if you want and just look at these final ones and just refer to the earlier ones if you feel the need.
Straight bottoms and flat decks
bck is offline
Old 03-30-2017 | 06:51 PM
  #262
bck's Avatar
bck
Charter Member#568
Originally Posted by articfriends
so a 700 hp motor at 1.05 cf has a friction factor of 5.25 hp added to cf vs observed? sounds about right compared to depac
I think the depac friction factor is slightly more generous or motor doesnt have quite 15% friction as at 2.8% CF am gaining 28 hp from CF at 663 observed when it would be 18.56 actually.
What this means to all the normal guys reading this who are scratching there heads: the higher your CF is on dyno, the less accurate your numbers are PERIOD. At one point Roccard came on here showing a 454 or 502 making 710 + hp w edelbrock 9-1 290 cc heads on 91 octane for sale, problem is he showed bsfc and lbs hr fuel used, motor used like 290 lbs per hr fuel at hp peak at .5 bsfc, he did NOT show CF used. So doing some real easy math, 290 x 2 (being bsfc was .5) is 580, thats how much hp worth of fuel he used at .5 bsfc, the numbers dont lie, so motor made 580 observed hp and was corrected 22.4 %, you would have to be dynoing in a monsoon at 5000 feet elevation to have a 22.4% CF, totally lies and BS, he quickly got ran off this board. You will ALSO notice that some very good looking dyno sheets from well known builders have been posted on OSO thru the years and you will OFTEN see BSFC and lbs per hr whited or blackened out, why, whats to hide??
Sounds like we need a thread devoted just to dynos and correction factors. So if you know the weather conditions you should be able to tell what the correction factor should have been? With the understanding that there are a couple acceptable standards they could be corrected to.
bck is offline
Old 03-31-2017 | 05:51 PM
  #263
articfriends's Avatar
Yes I actually started a thread a long time ago on Dyno correction factors and we had quite a discussion I also have went on Weather Underground for a location when somebody published a bogus dyno sheet, looked up all of the weather data looked up the altitude calculated the station pressure calculated the observe air density went on Wallace racing and we calculated what the dyno correction factor should have been. When I called out the very well known engine builder at that time and asked why he had a 16% correction factor instead of the 5% it should have been his answer was they were using very hot attic air to feed the motor
articfriends is offline
Old 03-31-2017 | 05:56 PM
  #264
SB
I'm glad I'm not the only dickhead here.
SB is offline
Old 03-31-2017 | 06:09 PM
  #265
my correction factors always seem to be .96-.99.
sutphen 30 is offline
Old 03-31-2017 | 06:33 PM
  #266
Ive dynoed with .97 cf before, made best power at about .380 bsfc too, anybody have a idea what it was? (SB, YOUR NOT ALLOWED TO ANSWER)
Old 03-31-2017 | 08:01 PM
  #267
You would think yes BUT with depac they read about 9% higher because of this k factor/friction factor
So lets say the HP was 753 corrected on sheet, and 685hp observed. The correction factor listed 1.0736 on sheet.
685 x 1.0736 = 735hp
685 x 1.0836 = 742hp
685 x 1.0936 = 749hp
685 x 1.1035 = 755hp
Seems like while the correction factor was 1.0736, it actually added about 9% to the observed number with Depac. Air Temp listed at 84.6 F, 29.211 baro, SG .751,
MILD THUNDER is offline
Old 03-31-2017 | 08:11 PM
  #268
Lets go
getrdunn is offline
Old 03-31-2017 | 08:23 PM
  #269
SB
Originally Posted by getrdunn
Lets go
Would be cool, but Braap is still in the air. 8"-12" tonight. Bay ice has thinned down, but still plenty thick for a car at 16".
SB is offline
Old 03-31-2017 | 08:34 PM
  #270
rc motor
