Good oil thermostats?? >
Old 05-05-2017 | 10:30 AM
  #91
Originally Posted by liquidlounge
First off, thanks for posting as experts usually tire quickly of internet forums. There does seems to be a bit of evidence that the beehives in higher lift (ie Crane HR series) big block applications (heavy valve trains) were having a bit of a tough time. I believe it was Rayler who was finding this out first hand. Also when gathering parts for my project, the tech at PAC advised against going with the beehives in my application. It is easy to see that a beehive would have some inherent advantages or they wouldn't be so prolific in the OEM performance applications, but maybe for higher lift, BBC applications they may not be the best. Any comments?
I think the answer to this would depend on what you define as "higher lift". If we're talking about .600" and above, then we might have a discussion on our hands. If we're under .600" lift, then there are a number of options available to consider in a beehive design. What it would really come down to is what the stress levels are in the application.
NautiSouth is offline
Old 05-05-2017 | 10:42 AM
  #92
SB
Crane HR's typically use .610 to.632" lift with 1.7 rockers. Mild mid 220 at .050" to 242 at .050 durations.
SB is offline
Old 05-05-2017 | 02:31 PM
  #93
Can't remember the last cam I put in a big block with less than .600
Unlimited jd is offline
Old 05-05-2017 | 06:13 PM
  #94
Hang Time 27's Avatar
yea, been wondering why I haven't seen the behives move into the big block world. In my SBC in my 64 Vette I run short travel hydraulic rollers, 240's/575 lift with 1.6 rockers, behives with titanium retainers - right up to 7,000 rpm. Maybe that's their limit on lift? even though I'm not running the highest rate ones... Although the LS motor guys (cars) are running crazy high lift numbers with them I thought?
Attached Thumbnails Good oil thermostats??-193496_1712216077637_6005287_o.jpg
Hang Time 27 is offline
Old 05-05-2017 | 08:52 PM
  #95
There's a lot of technology inertia in the performance aftermarket, I find. Once a certain solution is known to work, the development stops.
Old 05-06-2017 | 07:13 AM
  #96
I've only seen a few beehive springs in marine big blocks. And they've all been broken in short time.
Old 06-11-2017 | 11:35 PM
  #97
Rhythm and Blues's Avatar
Tim, what did you end up running for your final oil cooler thermostat setup? Also what are your ambient lake temps and what are you running for oil pans?
Rhythm and Blues is offline
Old 06-12-2017 | 08:42 AM
  #98
Full Force's Avatar
I didn't care for the temps I saw with the stats, so I removed them.
i run engine to collect and back again like I always did, see average of 150 ish after cooler max of 220 ever after miles of WOT.
pans are 12 qt
no water stats I average 130 water temps
water right now is 60 ish degrees
Full Force is offline
