Running Hard: RPM + Distance
#152
#155
Yes, grand haven/spring lake was getting bad a few years before I moved up north. Lots of good times and memories down there but up north they don't even look twice at a load boat. I remember blue moon having turn down detachable pvc pipes then on his 25 checkmate. Looked a little goofy but got the job done.
#156
i just want everyone to know I will have the baddest gladiator (SINGLE-ZERO) in Michigan next summer. I run SINGLE-ZERO soo god damn hard I don't let off till the oil pans have matching windows on BOTH sides of the pan, not just 1 side. I also break SINGLE-ZEROS drives occasionaly because I believe in driving SINGLE-ZERO hard as fuk. SINGLE-ZERO will have fresh N/A motors and drives AND will continue to run over the century mark. SINGLE-ZERO is sadly only a pleasure gladiator with bravos but none the less SINGLE-ZERO has both hour meters AND gas gauges. SINGLE-ZERO's motors will be ran just as hard, if not harder than unleashed I can assure you. SINGLE-ZERO will be at Boyne Thunder and Thunder Fest and everyone is more than welcome to come tell me how badass it is. I ask that you refer to SINGLE-ZERO as SINGLE-ZERO and not just as "your boat" when talking to me.
thanks
Driver AND throttles of SINGLE-ZERO
thanks
#157
thanks
thanks
#158
thanks
thanks
Straight bottoms and flat decks
#159
As far as SINGLE-ZEROs fuel consumption ill just say this. SINGLE-ZERO burns a lot. When I say a lot, I mean SINGLE-ZERO burns it all, every time I splash it, SINGLE-ZERO is either idle, or wide fukin open boys. SINGLE-ZERO holds the factory 75 a side. SINGLE-ZEROS handler, me, cant afford fancy race bladders.
Last edited by THE 288 KID; 02-25-2017 at 07:26 AM. Reason: Typing my boats name soo much I fuked up and added an s on the end
