Electric water pump, yay or nay?
I recently purchased a Pachanga 22 with a lightly built 7.4. It had the circulation pump removed in favor of a crossover. Since I boat 100% of the time in saltwater I plan to convert it over to closed cooling, obviously requiring the installation of a circulation pump. The previous owner was 100% freshwater lakes, so the cooling system wasn't a concern then.
I've been considering using an electric pump like this one:
https://www.summitracing.com/parts/s...make/chevrolet
It'll bolt right in without having to re-do any belts or add pulleys, and we do a fair amount of slow speed cruising in the ICW where the specs seem to favor the flow rate of this pump over a mechanical.
Any cons I'm missing?
thanks!
thanks!
I used to run an Electric Meziere on my LSx motors. Liked em a lot .
Used to run them after the motor was off and in between runs to cool the motor down.
I say go for it, I never had an issue with one.
For a drag or show car or something, electric is fine, but i like the belt driven pumps on a boat. I have never had an issue with one.
I have had automotive pumps weep antifreeze but never a salt water marine one weep, even from a 1986 mercruiser engine. Go figure
used several elec pumps for drag race setups, just put on on my son's LSX setup using the BB summit one and adapters, seems fine, I think in a boat I would use std pump though, as they really are not designed for long running times..
