New 1100hp BBC build. >
Old 03-03-2017 | 06:25 AM
articfriends's Avatar
Originally Posted by getrdunn
I remember seeing this 598 a while back in the swap. I can't validate build nor dyno sheet however thought I'd post it for the heck of it anyway. Pump gas? There was no build sheet but I'm assuming.
That's quite the bogus dyno sheet, wonder where it was dynoed at, do you remember where the guy was from selling it? 1000 observed hp, corrected to 1178 and bsfcs that are almost 1 lb per hp!
articfriends is offline
Old 03-03-2017 | 08:14 AM
What about freshening what you have, sell the 10-71's carbs, chillers etc and switch to whipples, mefi4 and a new cam?
Unlimited jd is offline
Old 03-03-2017 | 12:06 PM
The block is at it's max bore and would need to be sleeved. I put new rings it before keywest 2 seasons ago. The motors run great but its time and just easier to stick with what we got. I'd probably just go merc 1075 if I were to get rid of everything.
JJ30 is offline
Old 03-03-2017 | 12:57 PM
47excaliber and I were just talking about this on the way home.could copy the engine build thats in his boat,I'd go w/ bigstuff3 but thats me.
sutphen 30 is offline
Old 03-03-2017 | 01:16 PM
Big stuff is nice, was just thinking expense. Mefi will save a few bucks.
Old 03-03-2017 | 03:29 PM
Remember I'm just passing on info posted. Lol
http://www.offshoreonly.com/forums/s...u-1200-hp.html
getrdunn is offline
Old 03-03-2017 | 03:36 PM
Oh my...
getrdunn is offline
Old 03-03-2017 | 05:34 PM
You are smart to freshen before major problems! Good used blocks sell easy for decent money, might want to look into new blocks. The merc 1075 is cool but I wouldn't give up on your rebuild yet.
What parts are you considering reusing from your existing build?
offshorexcursion is offline
Old 03-03-2017 | 06:17 PM
We won't be sleeving the old blocks, just not worth it. New dart blocks and heads with new internals is it what I'll be using. Everthing else will be reused.
JJ30 is offline
Old 03-03-2017 | 06:35 PM
Seems like your mind is made up, just curious what is current bore on the blocks? They start at 4.44 on the 900's but that's was many years ago
