604ci build. Ready run msd or ignition box? >
Old 03-22-2017 | 12:56 AM
  #81
Originally Posted by 5050
im not done yet. Engine builder is busy so we pulled mine off so he can get 2 more engines dynoed and another engine built. Should've bought profiler intakes, pulling dart intake off and head porter is going remove/rework the cloverleaf intake. Best pull was 840hp torque like a diesel. See if I can scrub another 25 out of it. New power is a drug addiction! I'm pretty confident 93/95. Would like to see click or two under century mark. Give some of my cig friends a run for there money
Nice results so far!
I like those sniper intakes! What about a tunnel ram?
Maybe try a larger carb also
offshorexcursion is offline
Old 05-14-2017 | 09:48 PM
  #82
[ATTACH=CONFIG]567423[/ATTACH][ATTACH=CONFIG]567424[/ATTACH][ATTACH=CONFIG]567425[/ATTACH]
Attached Thumbnails 604ci build. Ready run msd or ignition box?-img_0916.jpg   604ci build. Ready run msd or ignition box?-img_0911.jpg   604ci build. Ready run msd or ignition box?-img_0913.jpg
5050 is offline
Old 05-14-2017 | 09:49 PM
  #83
[ATTACH=CONFIG]567426[/ATTACH][ATTACH=CONFIG]567427[/ATTACH] final results
Attached Thumbnails 604ci build. Ready run msd or ignition box?-img_0831.jpg   604ci build. Ready run msd or ignition box?-img_0508.jpg
5050 is offline
Old 05-14-2017 | 09:55 PM
  #84
Nice!
getrdunn is offline
Old 05-14-2017 | 10:13 PM
  #85
Originally Posted by getrdunn
Nice!
Thanks. Yeah head porter did a good job on cutting the cloverleaf out, definitely helped. I think next time I'd use a profiler or brodix. Way to much time and money cutting dart to flow right on big cube engine.
5050 is offline
Old 05-15-2017 | 05:39 AM
  #86
I just went with the Brodix HV2001 intakes for my engines, but was also leaning very heavily toward the Sniper Jr. I had been running the darts also. The Dart is a good intake but as you know, you need to put money/time into it, for it to really work well. Either way, nice results.
endeavour32 is offline
Old 07-15-2017 | 09:58 AM
  #87
5050 what jetting did you end up running and what changes if any did you make on the dyno ? My combination is fairly similar to yours and I'm wondering what ended up working for you.
dandercam1 is offline
Old 10-17-2017 | 11:54 AM
  #88
Originally Posted by MILD THUNDER
I don't believe most marine EFI systems, rely on o2 sensor feedback for fuel trim.
Mercury Marine used to utlize a spark advance feature, that was based off RPM in the Thunderbolt V I believe. What it would do, is slowly increase the timing during cruise, and if RPM increased, it would keep it there or advance it further. They did this , to increase efficiency and response. It was called MBT , for mean best timing.
Mean-Best-Timing (MBT)
Spark Advance
During light load cruising, the ignition modulesearches for the optimal ignition timing. This is also accomplished by small changes to the spark advance. At a given RPM, the module will try to add a small amount of advance and wait to see if there is an RPM change. If RPM increases, it will try to increase timing more. The module will continue to advance timing until it no longer gets an increase inRPM. Conversely, if it senses an RPM drop, it will start to retard some of the spark timing. The approximate RPM range for this feature is 1200-4000 RPM. Within this range, the ignition module can add approximately 10-15 degrees of spark advance to the base spark timing curve
I wouldn't say that MAP is strictly linear to RPM in boats. I can cruise at 3500RPM, with the tabs down and drives tucked, with a full tank of gas, and have a much heavier load on the engine, at 3500, then say, if I am in calm water, no tab, and drives nuetral with a light load of fuel. On my S/C engines, it could be a difference of being at say, 0", or 2-3lbs of boost, even though rpm is the same.
I know most thing that carbs are simply a garden hose with a ball valve pouring fuel into the engine, but the reality is, carbs are actually very good at metering fuel vs engine load. The key is, you kinda have to know how to tune them, and adjust them.
The daytona ignition setups, are certainly not a modern EFI comparison, nor are they meant to be. However, for those who don't want to spend the money to switch to EFI, they are imo, a much better choice, than the typical MSD marine box, that really does nothing for you.
The multiple spark they sell you on, isn't a "bonus feature". Its a requirement by design, that they NEED multiple spark at lower rpm, because they simply don't fire a single spark very well at low rpm. Thats with all Capacitive discharge ignitions.
I like the mercruiser ignition except for the fact that you can't reflash the ignition curve. Yes you get other modules but not quite right. I like my idle timing around 18-20 degrees and all in at say 3500-4000rpm. The engines start and idle much better. My module gives 25 degrees of advance. When it hunts for best timing who knows where it's at when under load and whether or not it's causing preignition .I need a curve with about 15 . So ive been looking at boxes and mechanical distributors. Does any one reflash these. Still worried about what it's actually doing when your on the gas. Twin 572 4.5x4.5
veloc410 is offline
Old 10-17-2017 | 05:14 PM
  #89
That wasn't question. I'm running 36 degrees locked out with distributor no box. My question is the need for msd box or not?
Supposedly msd and similar boxes give multi spark below 3000 and I've heard after that a long duration single spark of up to 20 degrees. Don't quote me on the 20 duration but it would be worth making a call. Yes definitely run better at idling without foul.
veloc410 is offline
Old 10-17-2017 | 05:30 PM
  #90
I'm curious how much power I'm going to leave on the table with 850 holleys vs 1050 QF. My drives certainly won't complain anyway.
Volumetric efficiency. Rpm , cfm calculator. You stuffing that engine so effiency is high
veloc410 is offline
