Oil pressure/Oil restrictors
Re did the motor about five years ago it was a ZZ502 block and we stroked it and made it a 540 even with a ZZ502 block the oil pressure was kind of the same situation I have now.the pick tube cracked last year and we put a new oil pump in it milodon 18760 and pick up tube and canton oil pan and block adapter. It had a meling hv pump in it before. Changed the oil lines to 5/8 id and the connectors are 7/16 id . The housing where the filter mounts is a stock merc unit. The clearances on the mains and rods are .002 . When we made it a 540 I also put a 30lb bypass valve in it
change the oil filter adapter to a moroso or canton and try a wix(napa gold) filter, I lost 15psi by switching filters once, scared the hell out of me...but the stock merc adapters I've seen are very restrictive..
Lucas racing 20/50, I run it in all my old muscle cars also because it has a high zinc content, when I pulled it apart when the pickup tube cracked the mains looked great and the rods had a little wear on them so I replaced them but they really weren't bad at all
I changed the adapter on the block to a canton , but not the one the filter screws onto , only filter I use is wix racing, been using them for years on the boat and my old muscle cars
Two of my cars I raced at the dragstrip and drive on the street I've always used those filters and never had an issue I got 500 passes on my GTX and I still haven't pulled it apart maybe this summer just to replace the bearings and hone and re ring it. Oil pressure is as good as when I first put it together 17 years ago
The stock filter head has a tiny passage inside of it. But it's super easy to just dremel it out to double its size.
Just info not trying to change the way you maintain your motor.
Wix 51060 flow rate 0f 9 to 11 GPM and filters at 21 microns
Wix 51060R flow rate of 28 GPM and filters at 61 microns
So the standard flow filter will filter a particle smaller then a human hair, the racing filter will let something that size pass.
I don't have high flow oil pumps in my car/trucks, but sounds like you do and may need the flow rate
[ATTACH=CONFIG]565511[/ATTACH]
