Oil pressure/Oil restrictors >
Old 03-12-2017 | 01:49 PM
  #31
Originally Posted by Baja Rooster
The stock filter head has a tiny passage inside of it. But it's super easy to just dremel it out to double its size.
Great thanks !! ill do that
89 warlock is offline
Old 03-12-2017 | 01:53 PM
  #32
Originally Posted by AllDodge
Just info not trying to change the way you maintain your motor.
Wix 51060 flow rate 0f 9 to 11 GPM and filters at 21 microns
Wix 51060R flow rate of 28 GPM and filters at 61 microns
So the standard flow filter will filter a particle smaller then a human hair, the racing filter will let something that size pass.
I don't have high flow oil pumps in my car/trucks, but sounds like you do and may need the flow rate
[ATTACH=CONFIG]565511[/ATTACH]
Yes I do have high volume pumps in them , thanks for your input very interesting
Old 03-12-2017 | 06:36 PM
  #33
If your fitting ID is 7/16 , your restricting the oil flow basically down to a - 7 . AN is sized by 16ths , 5/8 is 10/16 or AN -10. So your down between -6 & -8 through your
7/16 Fittings.
dunnitagain is offline
Old 03-13-2017 | 06:16 AM
  #34
articfriends's Avatar
Originally Posted by SB
Or regulator stuck open on the pump...wouldn't be a first time.
I seen a bypass in pump stick open before, under 900 rpms pressure dropped to zero.
articfriends is offline
Old 03-13-2017 | 06:20 AM
  #35
Good info
Old 03-13-2017 | 06:30 AM
  #36
7/16 Fittings.
Definately less than ideal at 7/16 id but if he really has .002 rods and mains the flow requirements to maintain static pressure wont be as high, i could also see it possibly being a restriction cold but hot I'd be looking harder.
Stock filter head with restrictive passages, they suck. Dont be afraid to take any steel adapters in your oil system that look restrictive and carefully port them if hard to find larger replacements. Ive seen hyd hose fittings on oil systems, terribly restrictive, not running 5000 psi so doesn't need as much beef! I also think if your engine builder didn't put in 30lb bypass and it was opening oil temp would be sky high
Old 03-13-2017 | 09:34 AM
  #37
bottom line is the merc filter mount belongs in the round file for anything other than a stock setup..
ezstriper is offline
Old 03-13-2017 | 12:05 PM
  #38
their is no getting around the fact that the smaller micron filter restricts flow,do i need a filter that restricts to 21 micron in my boat engine that get,s a new filter& oil change at 10 to 12 hours?NO.not with 20w50 motor oil.do i want 21 micron filtration in my daily driver that uses 5w30 and get,s changed every 5000 miles,YES.jmo.
mike tkach is offline
Old 03-25-2017 | 12:06 PM
  #39
Hi I really appreciate your input you seam to be the guy with a lot of knowledge with oil pressure issues, I've read your articles and they are very informative. Is it possible for me to call you and bother you for a 5-10 minutes of your time I would really appreciate it thanks
Ritchie
