cam shafts
Old 03-15-2017 | 10:07 PM
  #41
Lots of exhaust options just depends on how much $$$ your prepared to spend.
getrdunn is offline
Old 03-16-2017 | 12:05 AM
  #42
It's a boat. It'll eventually be every last penny in the bank account.
Baja Rooster is offline
Old 03-16-2017 | 01:37 AM
  #43
You don't need dry pipes. You need wet exhaust with long risers or tail pipes.
They can be headers with long tails or manifolds with long risers. The water mixes in with exhaust very close to the transom.
Be careful buying used stuff, especially if it had any salt usage.
Griff is offline
Old 03-16-2017 | 08:36 AM
  #44
I was running Eddie Marine on mine.. Reasonably priced and works well...
Boatally Insane is offline
Old 03-16-2017 | 08:30 PM
  #45
Dumping the water in as close to the transom as possible makes perfect cense, and the tall risers I take it are just a taller mountain the water has to climb to get back to the cylinders??? If I'm on the right track I have a couple ideas that should get the job done Thanks Griff.
Nova Rob is offline
Old 03-16-2017 | 08:43 PM
  #46
I hear yaa I divorced a 10 sec door slammer back in the late 90s and here I am hitched to a sea hag. I keep telling myself the Male gender is like a good wine, we take a little longer to mature, its my story and I'm sticking to my guns.
Nova Rob is offline
Old 03-16-2017 | 09:04 PM
  #47
Here you go. New, wet, good for future cam options and only 2,700.
http://www.hardin-marine.com/p-15730...st-system.aspx
getrdunn is offline
Old 03-16-2017 | 09:15 PM
  #48
Getrdunn I see you have tips for sale in the swap ill keep you in mind. I'm going to take my time and build a good flowing exhaust that doesn't rattle windows or bring every harbor cop along side for a shakedown.
Nova Rob is offline
Old 03-16-2017 | 10:04 PM
  #49
only? 2700. Good thing I scratched the Dart big M sportsman biock off the list in the first round of cost reduction efforts,
Nova Rob is offline
Old 03-16-2017 | 10:58 PM
  #50
I knew that was coming. I hear you. Look for a good used set of fresh water. Make sure their pressure tested before purchasing.
getrdunn is offline
